AAM return fuel system gas vapour smell problem
Old Dec 29, 2005 | 07:44 AM
vq35carel's Avatar
vq35carel
Its not just AAM I have a custom fuel return system by XS engineering and it smells in the **** pit as well. We are still worknig to resolve this issue.
Old Dec 29, 2005 | 07:55 AM
KShep's Avatar
KShep
If you're smelling gasoline inside the cockpit you may want to check the O-ring that seals the fuel pump assembly if you haven't aleady.
I'm still having this issue as well...but no noticable smell inside the car.
Old Dec 29, 2005 | 08:20 AM
booger's Avatar
booger
After I put a NEW Oring gasket thing on the cover that holds the fuel pump on top of the gas tank . NO smell at all . That gasket cant get any gas on it , or it will swell and not sit in the groove and will not seal right
Old Dec 29, 2005 | 09:50 AM
RedLeader's Avatar
RedLeader
Z-Car Garage cleaned up my installation from the tank all the way up to the plenum and said it was a matter of making sure all the connections were tight. There was a problem at the tank(not the o-ring) and clamping the lines properly. It may be because of the braided stainless lines with liners? They said the problem was solved.
Old Dec 29, 2005 | 09:40 PM
kim's Avatar
kim
even me ////
I was check more then 3 times .....
I think the smell came from the fuel line....
Old Dec 30, 2005 | 11:34 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Mine doesnt have any gas smell. There are lots of sources of very small vapor leaks, so it could be several things. First, there is a potential for vapor leak on the top and bottom of each injector. There should be one o-ring top and one on bottom. Some of the Greddy injectors included two o-rings for the bottom..not sure why. There is also potential for vapor leak from the fuel pump assembly, both around the return fuel fitting, and the large o-ring for the fuel pump assembly bucket. Lastly, large diameter SS -Ans fittings have been known to "sweat" a little bit. If there is a pronounced smell of fuel, I would check all of these areas. Look for dirt or gunk around all the SS fuel lines and fittings, just to insure there are no minor leaks...also around the FPR. Look for dust and residue, which is a sign of a leak.
Hope that helps.
Old Dec 31, 2005 | 08:56 AM
dlt1cy's Avatar
dlt1cy
I'd say replace the o-ring on the pump too. My smell/leak went away when I got a new one.
Old Dec 31, 2005 | 09:05 AM
phunk's Avatar
phunk
CJ Motorsports
Fill your tank all the way, then check the bulkhead fitting that goes thru the top of the fuel pump assembly for the return line.
Uriyo_
Sep 8, 2021 08:46 AM
