Oil cooler? Adv./Disadv.?
Old Sep 5, 2005 | 11:07 PM
mchapman's Avatar
mchapman
Originally Posted by Oleg
A rather crazy thought, so joke and laugh if you will, but has anyone considered putting an oil cooler in the back, similar to the Skyline Z-tune.
They are diff coolers not engine oil coolers.
Old Sep 5, 2005 | 11:33 PM
mchapman's Avatar
mchapman
Originally Posted by sentry65
how would an oil cooler compare to an aftermarket oilpan like the APS pan?
I was thinking about skipping the oil cooler and going with the oil pan for these reasons:
The weight is more towards the middle of the car
The weight would proably be lower
the pan would have oil baffles which are good for cornering and keeping oil delivery more consistent
more oil and heat fins vs an actual cooler up front
oil pan seems more simple since it's just one part. It's easier to install, no extra hoses or coolers for potential leaks or stuff to go wrong etc
how would an oil cooer vs oil pan compare as far as oil temp though?
What are other people's thoughts?
Larger baffled oil pan benefits, that I can see, are that it can take more heat away from the engine than a stock one before overheating because of its larger volume of oil, and oil will not wash away from the pick up under strong g forces because of it's baffles. A motor with an larger oil pan can still overheat, it will just take longer than a stock one because it has more oil to heat up. The cooling fins (if it has any, not all do) are generally not large enough to actually transfer enough of the oils heat to the outside air, cooling the oil and equalising the heat the engine is producing as you thrash it. Obviously this will depend on your engine setup and how hard and long you trash it but if we are talking about overheating the engine we can assume your donig it pretty well. While an oil cooler with its much larger surface area in direct air flow can actually cool the oil once it’s taken the heat away from the engine preventing it from overheating.
Old Sep 6, 2005 | 01:44 PM
Oleg's Avatar
Oleg
Oh well..., still looks crazy nonetheless...
Old Sep 6, 2005 | 03:05 PM
mchapman's Avatar
mchapman
They do look cool, i was at my mechanics this morning who has a race 350z with a massive custom diff, along with a host of other very cool modifications
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
