Oil cooler? Adv./Disadv.?
Old Jul 11, 2005 | 03:27 PM
Fletch69z's Avatar
Fletch69z
Default Oil cooler? Adv./Disadv.?
Hey guys, this may be a stupid question but I was wondering what are the advantages and disadvantages of oil coolers? Can I leave it on after I go FI? What about brands and costs?
Old Jul 12, 2005 | 11:54 AM
amolaver's Avatar
amolaver
like a radiator, you want to make sure it doesn't flow across the element when the oil is cold. make sure if you get a sandwich plate that it has a thermostat, or put one in-line. i've been looking to do this and racerpartswholesale has a decent selection of elements. i believe in another thread i posted links to the appropriate parts.
biggest question i have right now is where to place the element. might end up in a wheel well, although i'm nervous of it getting punctured by debris. post if you find a good place. i don't think i'll be able to put it up front with the radiator because my APS intercooler will be up there
ahm
Old Jul 12, 2005 | 02:00 PM
amolaver's Avatar
amolaver
Found my other post with links to appropriate sandwich plate and cooler. Last post on the first page.
https://my350z.com/forum/forced-induction/125662-finally-did-it-aps-tt-on-order.html
You'll need to get lines fabbed and a place to mount the cooler, but this is what I'm planning on.
ahm
Old Jul 15, 2005 | 11:30 AM
socalsean's Avatar
socalsean
Stillen makes a complete bolt on kit but I'm not sure how it will fit with a front mount. If the lines are long enough you should have ample space to mount it somewhere up front. Best place would be up against the radiator so the cooling air goes through both the radiator and oil cooler at the same time. Make sure both coolers are as close to each other as possible so air flow can't escape between them.
sean
Old Jul 16, 2005 | 07:34 AM
Fletch69z's Avatar
Fletch69z
What about adv. and disadv.?
Old Jul 18, 2005 | 04:27 AM
amolaver's Avatar
amolaver
so long as the system is thermostatically controlled, the only downside i can think of is its another system that something might go wrong with (mechanical failure - hose, thermostat, sandwich plate seal, etc). on the upside, keeping oil temps down should help prevent spun bearings due to oil thinning out due to heat and coking (assuming you have oil-cooled turbos). under load, the turbos are going to add a lot of heat to the oil. since my car does/is going to see lots of track time, i think this is a critical piece. YMMV,
ahm
Old Jul 18, 2005 | 06:18 AM
Fletch69z's Avatar
Fletch69z
Cool, thanks amolaver. So, if NA it's not really necessary or advantageous, right?
Old Jul 18, 2005 | 06:28 AM
Lawn Dart's Avatar
Lawn Dart
Also, it adds weight, but I doubt that you will be able to notice a difference.
Old Jul 20, 2005 | 07:32 AM
socalsean's Avatar
socalsean
ahm
All turbos are oil cooler/lubricated and some also have provisions for water cooling. I actually disconnected my water cooling lines from my turbo since they became a hassle and just let the car idle down for a minute or two before shut down.
Even N/A cars can benifit from oil coolers if the temps are getting high in the range. The increased longevity of the engine far outweighs the added weight of the complete system. I don't think it could weigh more than 20lbs at the most.
sean
Old Jul 20, 2005 | 07:43 AM
Fletch69z's Avatar
Fletch69z
sean
I just know that in some DVD's that I've seen when they are comparing the Z to other cars they sometimes say "We have equipped the Z with an oil cooler for this comparo." So, I didn't know if this was just sort of a benificial thing or a necessary thing if you are going to be running your Z hard. As of right now I don't track it very often and have very minimal mods so it's probably not necessary but I just wondered. Thanks!
Old Jul 20, 2005 | 02:14 PM
EnthuZ's Avatar
EnthuZ
Interesting thread. What I find odd is that people are buying & installing oil coolers without having measured their oil temps......
I am in the process of installing a Defi oil temp gauge, measuring at the oil pan. I will wait to see if I need an oil cooler. After over 30 HPDE's, running Mobil 1, I have not found a NEED for a cooler.....yet. Too cool oil does as much damage as too hot oil, so I am being cautious.
Now, does anyone know the optimum temp of the oil? I have heard 220 degrees F, as this is above the boiling point of water, so any water in the oil will still be burned off.
From experience, I have found thicker oil CAN run hotter than thinner oil......
Old Jul 20, 2005 | 03:05 PM
sentry65's Avatar
sentry65
the burninator
how would an oil cooler compare to an aftermarket oilpan like the APS pan?
I was thinking about skipping the oil cooler and going with the oil pan for these reasons:
The weight is more towards the middle of the car
The weight would proably be lower
the pan would have oil baffles which are good for cornering and keeping oil delivery more consistent
more oil and heat fins vs an actual cooler up front
oil pan seems more simple since it's just one part. It's easier to install, no extra hoses or coolers for potential leaks or stuff to go wrong etc
how would an oil cooer vs oil pan compare as far as oil temp though?
What are other people's thoughts?
Old Sep 5, 2005 | 09:42 AM
arizzee's Avatar
arizzee
Any update on this? I'm getting ready to do the same (Defi Oil Temp).
Old Sep 5, 2005 | 12:52 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Interested as well. I don't want to add more unnecessary weight to the front of the vehicle if my oil pan will do the job
Old Sep 5, 2005 | 02:50 PM
EnthuZ's Avatar
EnthuZ
Well, I did finally hook up the gauge. But the d*mn thing doesn't work!
I guess I'll have to break down and take it to someone more knowledgeable than I to figure out where I messed up.
I did put the sensor in the OEM oil pan, and at the time of the install I added a JWT oil pan spacer.
Old Sep 5, 2005 | 04:11 PM
undrgnd's Avatar
undrgnd
Just a couple of thoughts... The oil cooler which comes standard in our cars appears to be well designed at first glance since it uses engine coolant for the cooling medium, hence it cannot get 'too cold'. It would appear to maintain temperature at or above 190F under steady state conditions. As far as the oil pan cooler (fins) goes, you have no control over temperature, and in a cold environment that may be a factor.
Old Sep 5, 2005 | 04:24 PM
sentry65's Avatar
sentry65
the burninator
yeah, but if you have a hot engine, or don't live in a cold climate, I don't see an issue with the heat fins on the oil pan
Old Sep 5, 2005 | 07:09 PM
Oleg's Avatar
Oleg
A rather crazy thought, so joke and laugh if you will, but has anyone considered putting an oil cooler in the back, similar to the Skyline Z-tune.
Old Sep 5, 2005 | 08:02 PM
sentry65's Avatar
sentry65
the burninator
yeah or what about under the car facing down?
Old Sep 5, 2005 | 08:13 PM
meatbag's Avatar
meatbag
My oil cooler is going in one of the side openings in my greddy front bumper. But i live in houston, TX where it is always very hot.
