Rogue Shifter....nice!!
Old Aug 31, 2005 | 06:05 PM
D350Z10's Avatar
D350Z10
Is the B&M really that bad, how bad is the noise, worse than stock, i am trying to find the best/ shortest shifter! Please help me out
Old Aug 31, 2005 | 06:10 PM
chachi999999999's Avatar
chachi999999999
All I have to say is that I have the Nismo 4-Stage Adjustable Short Throw and it is probably my most favorite mod I have on my car and well worth the money.
Old Sep 1, 2005 | 05:31 AM
Z33's Avatar
Z33
I've had the original RE SSK for about 9 months, and it continues to satisfy with short, quick shifts. After the first couple of months, the initial increased effort had lessened as the shifter wore in and actually became smoother (this is with a new cup and quality synthetic grease). No vibration problems, doesn't seem any more notchy than stock. I'm considering swapping the Voodoo Pearl Magnum **** for titanium, but the shifter is here to stay.
Old Sep 1, 2005 | 02:04 PM
SnakeBitten's Avatar
SnakeBitten
Maybe your hands got stronger from the initial workout
I think Ill have to try it..I have an 05 and the shifter shakes rapidly ..Only 750 miles on it....However I have noticed girls playing with it and looking at it longingly
Old Sep 1, 2005 | 02:50 PM
ZZtopp's Avatar
ZZtopp
Better hurry.....I hear that the RE shifter has been discontinued.
Old Sep 1, 2005 | 07:40 PM
rgcarmack14's Avatar
rgcarmack14
Where did you get it? I have never even heard of it. Thanks.
Old Sep 10, 2005 | 10:52 AM
jasonbokamper's Avatar
jasonbokamper
I just ordered the Rogue shifter...how do I get a new cup. From the dealer?
Thanks,
Jason
Old Sep 10, 2005 | 11:59 AM
rgcarmack14
Thanks,
Jason
I had Rogue shifter installed yesterday. I bought it from 350evo and they had the cups listed with it so I went ahead and got one. It is like $11. I really like this shifter - very tight and absolutely no noise/rattle which is what I was after. Hope this helps.
Old Sep 11, 2005 | 05:08 PM
Faizei's Avatar
Faizei
Originally Posted by symalik
i just installed mine on my 05 coupe last week and its awesome. definately a little bit more effort to shift but shifts perfect, its very precise and definately less vibrations. never have to search for the gate, it just glides away. would recommend it for sure, but when you do get it, get the shifter cup too for like $10 because its worth it. taking the old one has to be hard, because putting the new one on took some work as well.
Just ordered the Rouge short-shifter from 350evo and the Shifter cup. However, in their instructions, they recommended changing the OEM cup as well. Does anyone know where to order this part or know if you have to change this part when installing this short-shifter? Thanks in advance.
Old Sep 12, 2005 | 09:49 AM
03Screamer's Avatar
03Screamer
I'm rather dissapointed with my rouge shifter. I got it about 3 weeks ago from 350evo, and it's the updated one with the bolt through the center. The shifter worked great for the first week or two, but then the upper peice of the shifter started to become very sloppy and loose. I really think the two peice design with the rubber isolation peice is a joke, and the fix they came up with the bolt through the center was just a band-aid fix...not much thought went into it. Yes, the bolt keeps the top piece of the shifter from coming off, but doesn't fix the slop that can show up overtime. Most people haven't had issues with their Rouge's, so maybe I just got a bad one. I went on a serious drive this weekend and realized how bad it was, 5th to 4th downshift was totally vague and mushy. I ended up taking it apart yesterday and using JB weld to secure the rubber isolating piece to the lower part of the shifter, and then doing the same to the upper piece of the shifter. It feels great now, hopefully it holds up. I'm still considering going with the 350evo shifter, since the throw on the rouge isn't all that short, and I don't mind a little bit of notchiness(sp) with the shorter throw.
Old Sep 12, 2005 | 10:11 AM
sentry65's Avatar
sentry65
the burninator
weird, on 350EVO's site, it says their shifter is a 20% reduction
isn't the rogue a 20% reduction as well?
the B&M is 33%
apex locator
Oct 6, 2015 05:58 PM
ScoBic
Dec 6, 2004 03:00 PM
ScoBic
Nov 9, 2004 07:31 AM
