what else...
Old Dec 8, 2002 | 02:14 PM
ares's Avatar
ares
Veteran
yeah Im all for vq's suggestions.
just dont set yourself in stone, if another exhaust comes out that works better, go for it. same with another body kit. tho I assume you like that one, you might find another even nicer.
Old Dec 8, 2002 | 05:04 PM
ares's Avatar
ares
Veteran
most modification are on the way, not here yet. that goes for the good brands of parts that are out too.
greddy should have the TT out early next year if we're lucky.
if you go that route, you will likely need an experienced shop to tune your engine. valves, rods, pistons, sleeves, who knows what else COULD be replaced to allow for more power from the turbos. it all depends on how much power you have and how much you want to spend.
Old Dec 8, 2002 | 11:30 PM
12SecZ's Avatar
12SecZ
I would upgrade the alarm on that sucker after all them dollars. Something with 2-way paging. The stock alarm doesn't even have a shock sensor. You have to full breach to set it off and usually by then it's too late. Even smashing the window won't trigger the stock alarm.
Nj350track
Nov 6, 2013 07:32 PM
vagel72
Dec 13, 2012 11:10 AM
