Chip upgrade with Cams?
Old Aug 4, 2005 | 11:43 PM
WestCoastRiot's Avatar
WestCoastRiot
Default Chip upgrade with Cams?
If i change the cams in my 02 350z will i need to do a chip upgrade? Im used to BMW's sorry for a simple question
Would the car run with the upgrade cam and NO software upgrade?
How much better will the gains be if i did both?
Can we also list some cam suppliers in this thread?
Thanks,
W C R
Old Aug 5, 2005 | 12:07 AM
kcobean's Avatar
kcobean
Thanks,
W C R
I'm guessing you mean '03 350Z, since there was no 350Z in '02. Also, the 350 doesn't have a "chip" per se. The ECU is reprogrammable by one of several companies, either Technosquare, or AAM. It's not required for a CAM upgrade, but it would help you to see the most gain for the $$. Unsure what the gains would be with or without the ECU reflash. If you repost your question in the Engine/Drivetrain/Performance section, someone in there will surely be able to answer it for you. Good luck.
Rev_Night
Nov 7, 2020 06:00 PM
