6MT final drive swap (again)
Old Aug 8, 2005 | 08:29 AM
Oleg's Avatar
Oleg
Default 6MT final drive swap (again)
When putting the 6MT final drive gear into the 5AT car, how long should the swap take, is it a direct swap, or does it require anything complex and how much should I pay for a used part (maximum)?
Thanks.
Old Aug 8, 2005 | 08:31 AM
zachcrosen's Avatar
zachcrosen
If all goes as planned, I am swapping mine out this weekend.
Old Aug 8, 2005 | 12:56 PM
booger's Avatar
booger
Its not easy and should be done by some one thay knows rear ends . It has to be shimmed and put in ....taken back out and shimmed again....who know how many times to get it to fit just right . Your best bet is to swap out the whole rear end...not just the pumpkin and not just the final drive gear . You can pick up a rear end for $300 to $500 and do it your self
Old Aug 8, 2005 | 03:36 PM
Binictican's Avatar
Binictican
Default Ok, I don't know my Azz from a hole in the ground
What is a whole rear end?
Old Aug 8, 2005 | 03:42 PM
booger's Avatar
booger
un bolt the half shafts...the drive shaft.....and thats whats left..the whole rear end
Old Aug 8, 2005 | 05:22 PM
zachcrosen's Avatar
zachcrosen
Alright.. Now you lost me here. I thought that swapping the pumpkin involved unbolting the half shafts and the drive shaft and that was it. Maybe I just dont know what is involved in this process. Please clarify Bill!
Old Aug 8, 2005 | 05:29 PM
booger's Avatar
booger
If you go to the back of your car and get down and look at your rear end . You will see a roundish plate on the back of the rear end with 8 to 10 bolts all around the out side edge of it . Thats the pumpkin...well the large set of gears inside that plate are...At least thats what Ive called it
Obadabot
Jun 18, 2023 11:31 PM
Stevo Z
Oct 3, 2015 09:14 PM
350z82
Oct 1, 2015 06:25 PM
