Optima Battery
Old Aug 11, 2005 | 01:29 PM
ecorona6's Avatar
ecorona6
Default Optima Battery
I was wondering if any of you have an Optima battery on your Z. I am in the market for a new battery and I noticed that the Optima has opposite posts that the original battery terminals possibly wont reach. I dont want to relocate or spend for new terminals I just want a nice easy exchange.
If you do have an Optima is it a red or yellow top?
Thanks..... Ed
Old Aug 11, 2005 | 02:07 PM
hbenet's Avatar
hbenet
Wrong forum.
I've seen many Z with the Yellow Optimas.
Do a search, I am sure you'll find many hits.
Cheers.
Old Aug 11, 2005 | 02:49 PM
VO...'s Avatar
VO...
Administrator
Not worth buying. If it's power you need, get an alternator upgrade.
Old Aug 11, 2005 | 02:58 PM
King Tut's Avatar
King Tut
They sell them with the terminals reversed as well. Normally the part number just has an R for reversed.
Old Aug 11, 2005 | 07:41 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I have a yellow top, fits just fine.
Old Aug 11, 2005 | 08:32 PM
ecorona6's Avatar
ecorona6
Thanks for the insight! I am not looking for increase in power, but a battery that will hold all my future audio/video and my upgraded HID headlights!
I didnt know Optima offered reversed posts. Thanks
Old Aug 11, 2005 | 08:56 PM
KingOfV6's Avatar
KingOfV6
I have a friend with the exact same setup as what ur thinking of doing and he says its enough juice....i approve
Old Aug 11, 2005 | 09:50 PM
Badmonkey's Avatar
Badmonkey
What is the difference between the red and yellow Optima batteries?
Old Aug 11, 2005 | 09:55 PM
05 NISMO's Avatar
05 NISMO
Got the opitma battery and had to get a longer negitive wire, I got the yellow top match my ultra yellow z, gotta love the setup.
Old Aug 11, 2005 | 10:10 PM
sentry65's Avatar
sentry65
the burninator
i'm puttin a hawker odessey in my car...
Old Aug 12, 2005 | 12:05 AM
The Mike's Avatar
The Mike
HIDS draw less current than standard halogen incandescent bulbs.
Old Aug 12, 2005 | 03:57 AM
DavesZ#3's Avatar
DavesZ#3
The reds are for normal everyday use. The yellow is a deep-cycle battery suited to the needs of cars with lots of extra power requirements, i.e. big amps, etc.
http://www.optimabatteries.com/publi...e/starter.html
Old Aug 12, 2005 | 09:47 AM
AZ350Z's Avatar
AZ350Z
What is a hawker? Weight? Race-only?
Thanks
Old Aug 12, 2005 | 12:05 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I have the yellow top, but most people recommend red top? not sure..
I have the reverse post, so you don't need to extend any cables, etc.
Old Aug 12, 2005 | 12:32 PM
sentry65's Avatar
sentry65
the burninator
hawker odyssey PC680 battery
it weighs 13-15 lbs depending on if you get the heat shielded one or not (I think it's worth it)
yellow top optima weighs about 25 lbs
stock is around 35 lbs
It has less voltage. Not good for stereos
If you left your ignition in the "ON" position and ran the stereo or left your headlights on, you'd drain the battery in about 18 minutes.
It's tiny compared to stock. You have to create a custom battery holding bracket.
It's actually more of a motorcycle battery, but people run them in their cars and have no issues. So yeah I guess you could say it's a racing battery
Old Aug 12, 2005 | 12:46 PM
ecorona6's Avatar
ecorona6
You learn something new everyday! Thanks
Old Aug 15, 2005 | 11:26 AM
Jun's Avatar
Jun
i bought the redtop, didn't know about the reverse terminals though, i so i had to buy the extenders (looks like a big mess, but luckily there it's covered by the battery cover).
Do you think they'll accept the exchange after 1 week use?
Old Aug 15, 2005 | 11:40 AM
xephiron's Avatar
xephiron
I bought the same one, the red top that was recommended for my car. Of course, the terminals were backwards and instead of trying to find extenders or modifying my car for a batter, I just returned it for a full refund.
So they make R (reverse terminal) ones? The yellow top one they had, which they said might work... was smaller, yet taller. dunno
Old Mar 14, 2006 | 08:06 AM
MeetJoeAsian's Avatar
MeetJoeAsian
sorry...i gotta renew this thread, since I don't want to start a new one...
what kinda of modification did ya have to do to fit the optima yellow top D35 into your Z, if you get the reverse terminal? if you get the regular terminal?
I'm still a bit confused here...some are saying the yellow top are deep cycle battery, meaning they are charged, used, drained, and THEN they can be charged again...so what would happen if you do not drain the battery completely...will that shorten the life of your battery? I don't plan to blow up my system everytime I get into my car, so is it wiser to get the red top? I'm just looking for a decent battery to run a small alpine 5 channel amp and 10" MTX, not any competition sound, and I don't want to f*ck up my HIDs or anything due to the amp drawing power from the stock battery....I just want to drive down the street and not have my HIDs flickering due to my sound system...
sorry if these questions don't make sense or common, I don't know much about car audio
Old Mar 14, 2006 | 10:10 AM
leemik's Avatar
leemik
I had a yellow top optima.. I currently have a red top 34R
The yellow tops are supposed to be able to discharge and recharge many times without affecting it's usefulness.. <-- i don't find that they deep cycle very well to be honest... The red tops have more cold cranking amps but are not deep cycle.. If you listen to your car system with the motor off a lot then, yellow top is probably better for you.. if you don't daily drive your car (aka. let it sit for days and weeks) especially in a cold climate.. the red top is probably better
--mike
