Why not underdrive?
Old Aug 17, 2005 | 09:07 PM
ReavTek's Avatar
ReavTek
I really like the KJR setup for the simple fact that since it is not underdriven you can use it with a supercharger. But, if you are going all out NA every bit of HP matters so I went with the UR Pulley Set.
Old Aug 17, 2005 | 09:24 PM
HockeyZ39's Avatar
HockeyZ39
Do you have noise from your UR 3PC Pulley Set? I cant handle squeeks, rattles, and so on! I do plan to stay NA, but I plan to throw a DVD screen in the cubby hole and I have a custom sterio as is, would underdriving be ok with stuff like that installed?
Old Aug 17, 2005 | 10:17 PM
defex's Avatar
defex
The dangers of Power Pulleys and Understanding the Harmonic Damper
Read up. Very informative.
Old Aug 17, 2005 | 10:40 PM
cvt's Avatar
cvt
i just read that the harmonic dampner pulley problem does not concern the Z as it is internally dampened...
Old Aug 17, 2005 | 11:14 PM
defex's Avatar
defex
So not one of the problems described in the article affects the z engine?
If that's the case the 5-8 hp for 250 might be worth it..
Old Aug 18, 2005 | 02:16 PM
ReavTek's Avatar
ReavTek
I don't have any noise at all that you can hear from the cabin. I run the 3 piece set so maybe that works more quietly? Alot of people have found a slightly narrower belt will eliminate all noise but I think a polished aluminum will always be "louder" than stock. Ah well, I don't notice any noises... Test Pipe rasp is far worse.
Old Aug 18, 2005 | 02:33 PM
sentry65's Avatar
sentry65
the burninator
I have no noise with mine
Old Aug 18, 2005 | 10:25 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Me either love mine!
JETPILOT
Jul 12, 2006 11:14 AM
MikeKondilis
Jun 27, 2006 07:11 AM
FairladyZ34
Apr 26, 2006 07:25 AM
InjectedPerformance
Dec 31, 2004 11:57 AM
Driven
Oct 26, 2004 08:44 PM
