What to do next for mods?
Hey.. I need some guidance in some steps to take...
03 Enthusiast...
So far done..
New model.. INJEN RD AIR INTAKE
STILLEN GROUND WIRES
INVIDIA G200 DUAL EXHAUST
PRO-1 SHORTY HEADERS
CRAWFORD PLENUM POLISHED
UR CRANK PULLEY
At this point besides doing an ECU REFLASH by Techno.. am i at the point where i have to decide N/A OR Forced Induction?
Please let me know what my options are?
Thanks
03 Enthusiast...
So far done..
UR CRANK PULLEY
Thanks
yep... NA or boost. if you get technosquare make sure u get revlimiter increased and no speed limit so that atleast you can use those things when you get a turbo or SC. I guess u can do cams.
Eh. i say you just save up from now on if your for performance. FI costs a lot and NA won't get you anywhere. Thats what I plan on doing. I'm just going to get a TD exhaust and plenum and HFC and just save from there on.
If youre hard on spending cash, then cams, but installation is expensive.
Mmmmm...... probably higher compression pistons (11.0:1), stronger rods and Nismo S-tune Spec 2 cams (Int: 284/11.0mm, Exh: 268/10.5mm)....
cheers,
richie
cheers,
richie
cheers,
richie
cheers,
richie
Originally Posted by lukesnyder
Only problem with higher compression pistons is if he goes boosted down the road and wants to run 93oct.
I would strongly suggest to go for lightweight flywheel and the computer mod...
cheers,
richie
I would have to say test pipes, or atleast high flow cats... you have headers and a dual exhuast but still the bottleneck of your cats. Then dyno w/ af read-out and send that in for the techno ECU flash.
Tochigi_236
Sep 27, 2015 03:40 PM
