Automatic Transimission Fluid
Old Sep 2, 2005 | 07:55 AM
lowtempo's Avatar
lowtempo
Default Automatic Transimission Fluid
Im at 45k miles and havent changed my automatic transmission fluid. Has anyone with at /or to the same milage changed theirs yet?
Also, the manual says to use only Nissan AT fluid, has anyone used something other than nissan AT fluid?
Thx in advance.
Old Sep 2, 2005 | 08:45 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You have to use the J spec Nissan fluid or you will serious ***up your tranny!
Old Sep 2, 2005 | 04:12 PM
cvt's Avatar
cvt
i've asked the same question with not very many responses...one guy says fill for life....but there is no documentation i've seen that proves this
Old Sep 3, 2005 | 04:35 PM
zzzya's Avatar
zzzya
There is an TSB that states only the Nissan fluid is to be used and that the fluid never has to be changed. If changing is required then it is supposed to be performed by an authorized service department.
I on the other hand installed a VB upgrade and TC myself and this required a fluid change. I still used the Nissan fluid, which is like $10/qt. The hard part is getting the fluid level back in place without having a way to monitor fluid temps and that is probably the main reason for having a service department with a Consult II device perform the work.
Old Sep 7, 2005 | 09:37 PM
nizan's Avatar
nizan
Default response
dont u need a special key to check the fluid/dipstick? thats what the dealer told me regarding trans fluid. you are better off bringing the car to the dealer for this one.
Old Sep 7, 2005 | 10:10 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
matic j...
http://performancenissanparts.com/ca...oducts_id=3995
Old Sep 8, 2005 | 04:34 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
ON mine there's just a 10mm bolt onholding the dipstick in place. Unbolt it and your good to go.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
seagrasser
Oct 11, 2015 03:27 PM
