Bank 1 and Bank 2, which side is which?
Old Sep 13, 2005 | 02:03 PM
DayBlueZ's Avatar
DayBlueZ
Default Bank 1 and Bank 2, which side is which?
Is the passenger side bank 2?
and the driver side bank 1?
Old Sep 13, 2005 | 03:20 PM
g356gear's Avatar
g356gear
Pass side is the right bank...cylinders 1,3,5
Driver side is the left bank...cylinders 2,4,6
Old Sep 13, 2005 | 05:53 PM
Tekwon-V's Avatar
Tekwon-V
yes, you are correct.
Old Nov 21, 2007 | 07:13 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
found out the hard way, yall are incorrect.
in a usdm lhd 350z
passenger side is bank 1
driver side is bank 2
Old Nov 24, 2007 | 01:40 PM
Eazzy's Avatar
Eazzy
As a rule # 1 bank is the bank with #1 piston. Looking at a birds eye down at the motor it is the side that is farthest to the front, and yes, in this case the Pass side
On a Chev---#1 bank is the Drivers side
Old Nov 24, 2007 | 04:53 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
this thread cost me 77 bucks on a unneeded cam position sensor.
Nissan should really call the sensors bank 1 and bank 2, not just left and right since l and r are relative to how you look at the engine.
Old Nov 24, 2007 | 05:04 PM
Eazzy's Avatar
Eazzy
Future note: Its the Excepted Standard....Left is ALWAYS Drivers side and Right is ALWAYS Pass. side
Old Nov 26, 2007 | 01:01 PM
Q45tech's Avatar
Q45tech
In what countries? Obviously not AU, JP, UK, Bermuda, UK Carib, India, Indonesia, Pakistan, Bangladesh, Thailand, South Africa, Tanzania, Kenya, Nepal, Ireland, Indonesia and dozens more.
Old Nov 26, 2007 | 02:30 PM
Eazzy's Avatar
Eazzy
Do they not have Left and Right ??? It is certainly standardized here. RWD or FWD, Left is standing at the bellhousing. Oviously in Japan also, since Brackets, Shrouds, and Headlites are marked Left and Right standing at the rear of the Car facing the front
Old Nov 26, 2007 | 02:42 PM
Zivman's Avatar
Zivman
not really...
is your car a Right hand drive or left hand drive? obvious answer is that if your car is a left hand drive, wouldn't the left hand side of the motor = the driver's side?
Old Nov 26, 2007 | 02:44 PM
Eazzy's Avatar
Eazzy
Originally Posted by Zivman
not really...
That would make sense if I was standing on my head and looking in a mirror maybe
Old Nov 26, 2007 | 02:57 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
the problem was that the DTC code said "cam position sensor a Bank 1" and the part description was " cam position sensor a" Left or right. Even the parts guy didnt know. I had to figure out which side was bank 1 and which was bank 2. I went off the misinformation in this post and purchased the wrong sensor. Later, i read through the OEM service manual and saw bank1 and bank 2 clearly marked. I knew i bought the wrong sensor side so i had to buy the other side.
future note: Its accepted not excepted.
Old Nov 26, 2007 | 02:59 PM
iStan's Avatar
iStan
ZR
Future Note: Search FTL haha. Sorry to hear that though. That sucks.
Old Nov 26, 2007 | 03:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^lol, first time that searching has busted my *****. No biggie i guess, if one of these sensors was bound to die so was the other one.
What sucks is the dealerships labor rate. How do some of the techs sleep at night? they wanted 1.5hrs to change the bank 2 sensor and probably the same for bank 1. It took me 30 min to do bank 2 (have to remove TB and intake piping) and 15 min to do bank 1 ( removed PCV valve on plenum and the motor was hot) All it requires is a 10mm deep socket, 3/8" drive and youre set.
Old Nov 26, 2007 | 03:07 PM
iStan's Avatar
iStan
ZR
Comfortably.
Mattg350z
Oct 2, 2015 06:51 AM
samansharif
Sep 25, 2015 12:31 PM
