Oil Pressure at idle?
Old Oct 5, 2005 | 06:27 AM
Viffer35Z's Avatar
Viffer35Z
Default Oil Pressure at idle?
Just brought my Z in for it's first oil change yesterday. Previously, oil pressure at idle was around 60, maybe slightly less. After getting it back yesetrday, pressure is a bit less than 30 at idle and is much more variable through the rev range. It seems like it is right now, but just want to make sure.
Thanks guys!
Todd
Old Oct 5, 2005 | 06:35 AM
jwolf7722's Avatar
jwolf7722
Mine does the same thing. I run castrol full synthetic.
Old Oct 5, 2005 | 07:00 AM
undrgnd's Avatar
undrgnd
I don't think oil pressure of 60 psig at idle was ever normal. I assume you mean with a warmed up engine. On a stock vehicle, at NOP (normal operating temperature), at idle speed of ~700rpm, oil pressure should be no less than 15 psi, but nowhere near 60.
Old Oct 5, 2005 | 09:10 AM
Viffer35Z's Avatar
Viffer35Z
Thanks guys. I figure it wasn't right before and now the oil pressure gauge is reading correct. Appreciate you chiming in.
Todd
Old Oct 5, 2005 | 09:12 AM
lowrider's Avatar
lowrider
You "Z" guys can read yours, us "G" drivers have no Oil Pressure gauge or Voltmeter. Wish we did
Lou
Old Oct 5, 2005 | 05:24 PM
yeperra's Avatar
yeperra
With the oil that came in my car I was at 15psi. I changed the oil to Castrol 10w-30 and have seen a slight rise in pressure. Maybe 17 at idle or one needle width above the center 15psi mark. I get 60 psi on the road at 70mph in 6th.
Old Oct 5, 2005 | 05:29 PM
KTaylor's Avatar
KTaylor
wow mine is alot higher than that. when i get in the car in the mornings it well over 60 and at idle after it has warmed up its still alot higher than 15 probally between 30 and 40.
Old Oct 10, 2005 | 07:17 PM
spdkils's Avatar
spdkils
Oil pressure in the Z seems to be a crap shoot.
I've gone back and fourth between oils just to see what my guage will read!!!
The "dealer" oil (30w) runs about 10PSI lower then FS 10w-40 @ operating temp.
The service manual states like 10 psi @ idle, and 60 PSI @ 6000 RPM.
HOWEVER, many people on the forums have seen oil pressures in excess of 80PSI @ 6k RPM. (Me included.)
This is my one major concern with the engine. To tell you the truth I don't know what oil pressures of this level could/would do to the engine. And that is why I'm concerned... cause I just don't know what damage it will/may cause.
Old Oct 10, 2005 | 09:09 PM
homiusang's Avatar
homiusang
I was going to start a thread about my low oil pressure when the engine is idle at operating temp. I did an oil change not too long ago with Mobil 1 10w-30 (First time to synthetic) and notice the oil pressure at idle dropped from around 30psi with conventional oil, to now at 10psi.
Old Oct 10, 2005 | 09:43 PM
vitaminZ's Avatar
vitaminZ
I have the turbonetics kit. when my engine is completely warm, my idle is @900rpms (< due to reflash) and my oil pressure is right at 40psi. while driving, when at 3000rpms my oil pressure is right at 60psi. i use mobil 1 full sythetic 5w-30. takes like 10 to 15 minutes to completly warm up. Depends on whether i warm it up a bit then drive or just let it run for about 15 min before driving it.
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
apex locator
Jul 23, 2021 02:27 AM
