Unorthodox pulley....really worth it????
Old Oct 21, 2005 | 10:24 AM
DZ2005's Avatar
DZ2005
Default Unorthodox pulley....really worth it????
Alright guys, I already did a search but didn't really find what I was looking for.....I'm thinking about buying the Unorthodox pulley and was wondering if the gain in HP/torque was worth the cost. To you guys that have them, was it worth it?? Can you FEEL a difference with it on or what??? Anyways, any advice would help. Also I want to install it myself, is this a big deal? I already put on the groudning kit and I am fairly experienced with tools and such. THX Again!
Old Oct 21, 2005 | 10:29 AM
failsafe's Avatar
failsafe
....for your health
I didn't feel any noticable power gain. But did notice better throttle response.
Old Oct 21, 2005 | 12:13 PM
DZ2005's Avatar
DZ2005
Yeah I'm debating....$179 is a lot of dough for just barely any gain, I will do it if everyone says to but I'm not sure yet.....
Old Oct 21, 2005 | 12:24 PM
cvt's Avatar
cvt
i think there are dynos floating around that it gets around 6+whp....lemmie look
Old Oct 21, 2005 | 12:28 PM
EM-EFER's Avatar
EM-EFER
WELCOME to the world of the Z
Old Oct 21, 2005 | 12:46 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Improves low end power and the car whines out faster. It was a great mod for the money.
Old Oct 21, 2005 | 02:23 PM
DZ2005's Avatar
DZ2005
Cool I'll prob go with it then.....Thanks a bunch guys
Old Oct 21, 2005 | 05:55 PM
___DJK___'s Avatar
___DJK___
Its worth it for the improvement in throttle response alone.
Old Oct 21, 2005 | 07:48 PM
Mike Wazowski's Avatar
Mike Wazowski
Old Oct 21, 2005 | 08:02 PM
Vamos_Rafael's Avatar
Vamos_Rafael
do they need to lift out the engine to replace it?
installation would be expensive if so...
Old Oct 21, 2005 | 08:09 PM
djbit's Avatar
djbit
I'm about to get my KJR. I went with this one because you can use the stock belts.
170.00 is not bad either.
http://www.kjrperformance.com/products.htm
Old Oct 21, 2005 | 08:57 PM
Mike Wazowski
No. Pretty easy install
Old Oct 22, 2005 | 12:23 AM
DZ2005's Avatar
DZ2005
Does the KJR make as much of a difference as the Unorthodox pulley?? Anybody got a comparison or something with the two?? Thanks again!
Old Oct 22, 2005 | 08:16 AM
DZ2005's Avatar
DZ2005
Bump
Old Oct 22, 2005 | 08:21 AM
bio911's Avatar
bio911
u gain a little bit of power but it frees up a lot of weight.. rotational mass that is* and that will help the motor rev faster which is important.. i just ordered mine and i know it will make a difference.. compare the stock crank pulley to the UD.. a lot lighter.
Old Oct 22, 2005 | 09:50 AM
DZ2005's Avatar
DZ2005
Yeah but the question is, Unorthodox or KJR? Tryin to decide which one.....plus I think the KJR uses stock belts (saves a little cash)
Old Oct 22, 2005 | 03:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
have the UR and love it
Old Oct 22, 2005 | 04:00 PM
spracked's Avatar
spracked
UR pulley weighs little over 1 pound, kjr weighs a little over 2 pounds. stock weighs about 6 pounds. for every pound lost, its about 2whp gain.you do the math. UR all the way.
Old Oct 22, 2005 | 06:32 PM
JonathanAboona's Avatar
JonathanAboona
I've never held a UR pulley in my and but my KJR pulley weighs 2.020 lbs. From what I have read, the UR weighs around 1.6lbs but like said above needs new belts. Stock pulley weighs 6.43 lbs
dynos can be found at www.kjrperformance.com
Sold in Black and Billet
Old Oct 22, 2005 | 08:25 PM
idrmofs7's Avatar
idrmofs7
the pully bein "lighter" will mess with your harmonic balance. this pretty much means that your car will run real rough at idle only. Also all these aftermarket pully's will make your belts sqeal like crazy unless you get goodyear gaterbacks ,I think. but if you are tryin to get all the power outta yourmotor as possible then do it but it should be one of your last mods.also, try to get your crank re-balanced after.hope this helps
