JIC Carbon Fiber Strut Tower Bar and Motordyne Plenum
Old Oct 27, 2005 | 04:29 PM
mikerz's Avatar
mikerz
Default JIC Carbon Fiber Strut Tower Bar and Motordyne Plenum
Will the JIC Magic Carbon Fiber Strut Tower Bar fit if a 1/4 Motordyne Plenum Spacer is installed?
Old Oct 28, 2005 | 03:50 AM
mikerz's Avatar
mikerz
Bump
Old Oct 28, 2005 | 04:09 AM
taurran's Avatar
taurran
I'm putting one on this weekend. I have a 5/16th inch spacer installed. I'll let you know how much room I have.
Old Oct 29, 2005 | 03:57 AM
mikerz's Avatar
mikerz
ok, thanks...
Old Oct 29, 2005 | 05:31 PM
mikerz's Avatar
mikerz
BUMP
Anyone else
Old Oct 29, 2005 | 06:06 PM
taurran's Avatar
taurran
The body shop that has my car keeps pushing the date back. Hopefully I'll have it tomorrow....
Old May 4, 2006 | 10:20 AM
jwales's Avatar
jwales
I have the JIC Magic aluminum strut bar and the 5/16 MD Spacer. It all fits but with a slight bulge on the driver side.
Old May 4, 2006 | 04:48 PM
Zincognito's Avatar
Zincognito
Can you post some pics of it? i'm looking for the same strut bar. you guys wouldnt know where i could find the polished JIC strut bar??
Old May 4, 2006 | 07:16 PM
What is the distance between the top of the plenum and brace? Keep in mind that the plenum spacer comes with spacers for the OEM brace. The spacers will most likely fit the JIC brace.
Old May 5, 2006 | 11:33 PM
taurran's Avatar
taurran
This thread is kinda old. Realized I never updated it when my car was done...
Here is a good pic of how it fits on my car with the 5/16" spacer. I have an aftermarket hood and it slightly rubs in two spots, so I put some weather stripping on the underside of the hood to keep it from damaging the strut bar. I have to change out the weather stripping every so often, but it still works. I've been thinking of using some washers to lower it slightly on the passenger side to cut down on some of the rubbing. I might do this before I head up to Zdayz in two weeks.
Old May 11, 2006 | 08:20 PM
bamyi's Avatar
bamyi
what hood do you have? Have you tried it on the OEM hood? when installing the JIC strut, did you have to use the sapcers for the strut bar that Metrodyne provided?
I have the 5/16and wanting to get the JIC CF strut as well. Thanks in advance.
Old May 11, 2006 | 08:21 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
you need to use the strut bar spacer (included). If you're going to use aftermarket hood, forget it. It will not fit at all.
Old Jul 13, 2006 | 10:55 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Ide really like to knwo more info on this thread. I hate it that its old.
Id like to know what aftermarket hood is that read Z using. Also some more pics woudl be helpful.
Buble why do you say that it will not fit?
I have a Fuzion hood with the stock strutbar(no washers) and it fits with very very slight rubbing on the plenum and hood. I am trying to find a strutbar that owudl work better. Otherwise i will ahve to modify my stock strut a little to eliminate some of the little rubbing that exists.
Old Jul 13, 2006 | 01:14 PM
97supratt's Avatar
97supratt
Is there a aftermarket strut tower brace that is adjustable for the Z?
Old Jul 13, 2006 | 01:18 PM
IIQuickSilverII
dont think so...
i am willing to try the JIC maigc sturt bar since its "thiner than the stock one and i cang et my stock one to fit... Otherwise i am "filing" my stock strut bar in some areas adn then painting it black. Wont be the best performing strutbar but it works out for shows
Old Jul 21, 2006 | 02:42 PM
z33chillin's Avatar
z33chillin
I am also looking at this strut... will it fit with the crawford plenum????
hulkout
Apr 28, 2017 09:00 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
