UR vs JWT flywheel
Old 11-17-2005, 07:23 AM
southern_info
southern_info's Avatar
How many pounds does the stock flywheel weigh? My other question is will a lighter flywheel actually give you more horsepower/torque and if so do any of ya'll have dyno's to prove it? I've been reading around and 1 website, it stated 10-30hp increase. I don't see anything above 10hp for a N/A car. Right now I'm in the process of doing as much as I can to get the most out of my car N/A minus the headers because I'm still undecided on weather staying N/A or going F/I. What is the highest hp on a N/A car have any of ya'll seen with dynos to prove it?
Old 11-17-2005, 07:43 AM
ActionJackson
ActionJackson's Avatar
It doesn't add HP it just creates unsprung weight for your car giving you the feeling of more HP & Torque. I believe the lighter weight helps with the % HP loss from the drive train than helping you gain any hp.
Old 11-17-2005, 07:52 AM
steakpinoy
steakpinoy's Avatar
I would also recommend the JWT flywheel/clutch combo myself just like Rick. In my car, there is very little chatter, if any at all. Plus, you'll notice a MUCH BETTER throttle response throughout the rpm band. Finally, the quicker response of the flywheel makes it alot easier to rev match when you're either heel-and-toeing or other forms of rev matching.
Last note...See you at the Z/G meet this Sat Rick!!! Thx for puttin it together. I'll bring my g sedan though because I think I have to take more than one person unfortunately
Old 11-17-2005, 09:34 AM
southern_info
How much of a drive train loss does the stock z have as oppose to having a lighter flywheel and what would the drive train loss be with the lighter flywheel? Is it really necessary to change the clutch with the flywheel? I mean would an upgraded clutch make that much of a difference. Is it like how quick it would engage the flywheel or how hard? I'm just trying to understand the mechanics here of changing the flywheel as oppose to change the flywheel and clutch as a combination together.
Old 11-17-2005, 09:41 AM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
the logic behind changing the clutch and flywheel together is combining labor costs. A flywheel install takes ~4 hours. Add a clutch into that and it takes the same ~4 hours. Do one or the other now, and then one or the other later, and you are paying someone to do essentially the same job twice.
Old 11-17-2005, 09:53 AM
HarvesterUT
HarvesterUT's Avatar
do the entire install at the same time....you'll save $400 in labor!
also, the JUN is the best overall flywheel IMO simply because its forged chromoly (not aluminum) so its less likely to warp under heat/pressure and also comes balanced from the factory, wheres others might not, causing even more "chatter". It's also a 1-piece design so it can be resurfaced if needed
Old 11-17-2005, 09:59 AM
southern_info
Thanks! Does the upgraded clutch and flywheel just engage faster or harder than the stock flywheel and clutch? Is this the reason why peoples change both of them? How much of a drive train loss does the stock z have as oppose to having a lighter flywheel and what would the drive train loss be with the lighter flywheel?
Old 11-17-2005, 11:44 AM
ZlleH
ZlleH's Avatar
How about headers? Is there money saved on doing the flywheel as well when doing headers? Or are they not in the same area?
Old 11-17-2005, 12:20 PM
Alang35
Alang35's Avatar
i talked to a G driver with the jwt clutch and ur flywheel. he agrees that the ur flywheel makes less noise than the jwt. i heard his car at idle and i could barely hear any chatter at all from the outside. i will go with jwt clutch and ur flywheel when i finaly get totaly sick of the stock clutch.
04-22-2021 09:42 PM
11-09-2020 10:27 AM
silverbullet_Z
NA Builds
24
11-14-2015 02:52 AM
Quick Reply: UR vs JWT flywheel
