how much oil does the vq go thru?
Old Nov 7, 2005 | 07:04 PM
baileyrx's Avatar
baileyrx
Default how much oil does the vq go thru?
How much oil does the VQ go through between oil changes?
How about ya'll with FI?
Mine seems to go through alot!
Old Nov 7, 2005 | 07:15 PM
ANXIOUZ's Avatar
ANXIOUZ
I don't go through any but the normal amount.
Old Nov 8, 2005 | 03:46 AM
chimmike's Avatar
chimmike
look to the procharger for your cause. Prolly blowing oil right by the rings
Old Nov 8, 2005 | 06:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I have never buned more than 1/2 a quart within a 3K-4K mile range of Mobil 1 Synthetic. Most of the time its 1/4 quart or less, I love how this motor burns no oil. Im at 53K miles now BTW....
Old Nov 10, 2005 | 11:56 AM
bobS's Avatar
bobS
I'm not burning any high amount of oil either and i have 43k miles on the motor.
Old Nov 10, 2005 | 11:52 PM
papag1's Avatar
papag1
wow thats odd, i get to about a few quarts MAX. thats weird. putting 5 qts, coming out w/ a little over 1. if you drive really hard do you consume more oil?
Old Nov 11, 2005 | 02:27 AM
Z BOY's Avatar
Z BOY
lots of our cars have oil consumption problems.
Old Nov 11, 2005 | 05:44 AM
plumpzz's Avatar
plumpzz
if u put in 5 and take out 1 i think thats a rather big problem lol
Old Nov 11, 2005 | 06:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes...
Old Nov 11, 2005 | 07:35 AM
TK2005's Avatar
TK2005
I guess the good thing about that is that you never have to change the oil. Just keeping topping it off. It will always have fresh oil.
Old Nov 11, 2005 | 08:07 AM
Nano's Avatar
Nano
Oil consumption varies from oil brand to oil brand and depends on the use. It is normal to burn some oil inbetween changes. Internal combustion engines burn a little amount of oil each time the piston moves back and forth. As long as oil consumption is constant, there shouldn't be any problems.
with mobil one I was burning a 1quart every oil change
with motul I am burning almost none (1/10 quart every oil change)
Old Nov 11, 2005 | 08:41 AM
Thaddeus's Avatar
Thaddeus
My first Z, 2003 enthusiast, no oil burning to 1/3 Qt between oil changes up to NNA buying back at 50K miles. This using Mobil 1.
Current Z, 2005 enthusiast, less than 3K miles ....... no burning yet
Old Nov 11, 2005 | 12:05 PM
papag1's Avatar
papag1
LOL i guess i dont need the oil change just top off like mentioned. But I do use Mobile 1 10W-30 weight. And i have an extra quart in my car just to be safe. it is kind of odd that it goes through that much, but i REALLY drive my car hard thats why im not so concerned
Old Nov 14, 2005 | 06:33 AM
Phatmitzu's Avatar
Phatmitzu
I used to burn 1 qt per 3k miles oil change.
After gone F/I, 1 1/2 qt per 1.5k miles oil change(my first oil change since F/I).
Old Nov 17, 2005 | 09:46 AM
homiusang's Avatar
homiusang
Same here. I have mobil 1 10w40 and lost about 1/2 qt since my last oil change about 1.5k miles ago.
Old Nov 18, 2005 | 07:25 AM
Kolia's Avatar
Kolia
Pretty much the same here.
I burn at least one quart every oil change. Mobil 1 10w30.
High rev engine braking (ie- heel n toe and such) will burn more oil. The piston rings depend on cylinder pressure to push them hard on the cylinder wall and scrub excess oil back down the oil pan.
When we’re off throttle, the injectors shutoff, no combustion occur and we end up with a little pressure in the combustion chamber. Oil stays on the cylinder wall and get everywhere in the combustion chamber. It’s then burned when we get back on throttle.
Different oil will also behave differently. Mobil 1 has a good reputation for “evaporating” between oil changes!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
