PC interface and software
Old Dec 21, 2005 | 07:26 AM
  #61
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
So you think you could just tap into the OBD-II connection without having any signal degradation?
Dave
Old Dec 21, 2005 | 09:14 AM
  #62
oman_'s Avatar
oman_
Dave
Splitting the OBD-II lines is fine however having two diagnostics devices trying to read sensors at the same time will not work. If CIPHER (or any other tool) tries to communicate at the same time as your other device, neither one will work. It's best to just swap them out when you need to.
Old Dec 21, 2005 | 09:21 AM
  #63
oman_'s Avatar
oman_
Originally Posted by DomZ
I have one question, will Cipher allow me to run at FULL ADVANCE all the time?
CIPHER will let you run normal timing +2 degrees all the time. I'm not sure what you mean by FULL ADVANCE. Just take what your car does now and add 2.
Old Dec 21, 2005 | 09:35 AM
  #64
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Hmm, that might convince me not to get the Cipher, then. I know it has more functions, but I don't want to boot my computer every time, and I don't want to have to switch. Maybe I can make some sort of KVM type switch...
Dave
Old Dec 21, 2005 | 12:01 PM
  #65
dovla's Avatar
dovla
Dave
Whatever. How is your Blitz R-Vit connected now? Cable just plugged into OBD-II port? When you take the car to dealer, do you disconnect Blitz box?
Switch should work also.
What would be your needs for both Blitz and Cipher at the same time?
Old Dec 21, 2005 | 12:25 PM
  #66
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Whatever? Thanks for the sarcasm.
And no, I don't take my car to the dealer, I do my own maintenance. As for needs for both at the same time, any reason that concerns you?
Old Dec 25, 2005 | 09:22 AM
  #67
maximumsportZ's Avatar
maximumsportZ
So how much buyers do we have? I just placed an order.
Old Dec 28, 2005 | 02:40 PM
  #68
HyperSprite's Avatar
HyperSprite
Mad Scientist
I had the fortune to meet up with uprev this afternoon as he is in the bay area for a few days. He gave me a rundown of the software and hooked it up to my Z and showed me how it works. With logging and error code reading and clearing, it was very interesting. The gauges in action on the PC are awesome as well, this thing is way better than the data logger I was running on my palm.
Long story short, my order is in. I can't wait.
Chris
Old Dec 28, 2005 | 06:33 PM
  #69
oman_'s Avatar
oman_
Originally Posted by dovla
I have no intentions to have cables hanging around. Depending on if Cypher connector contains any parts in connector or not, I intend to either install additional OBD-II port in the upper glove box in G35 (where I keep USB hub), or have it hardwired to the back of OBD-II connector.
J1962F Assembly
CAN pins:
5 Ground
6 Data
14 Data
16 Power
Probably only pins 6 and 14 are needed.
In order for Cipher to work correctly (or any scan tool) it will need pins 4, 5, 7, 6, 14, and 16. Keep in mind that if you are extending/splitting the CAN bus (pins 6 and 14) you could introduce errors if you add signal reflection or otherwise change the electrical characteristics of the BUS. I'd suggest checking out the ISO15765 documents and doing lots of tests to make sure the ECUs in the car aren't throwing can bus related codes after you mess with it.
Old Jan 21, 2006 | 02:57 PM
  #70
RB's Titan's Avatar
RB's Titan
Default Keeping an eye on this
Just wanted to pop in over here and keep an eye on progress and perhaps learn a thing or too.
Old Jan 21, 2006 | 05:20 PM
  #71
smoaky396's Avatar
smoaky396
Default Friendly?
This might have already been coverd....so if it has i'm sorry.
I am very computer STUPID! and was wondering how user friendly this interface will be. I know that there won't be a botton that says " go fast" or anything...lol
Old Jan 21, 2006 | 05:50 PM
  #72
HockeyZ39's Avatar
HockeyZ39
Subscribed!
About to put my 7" LCD in my cubby, building a computer to link to it in the near future. Any updates on the re-flash part?
Old Jan 22, 2006 | 01:58 PM
  #73
rcdash's Avatar
rcdash
I have only begun to scratch the surface. This tool is amazing. Control of ECU, ABS, and BCM. And I mean control... I had no idea it would be able to put windows up/down, lock and unlock doors, open trunk, sound horn, turn on/off lights etc.
Amazing...
m_0g
Jun 3, 2021 10:05 AM
Workshop12
Mar 23, 2020 01:45 PM
alphared
Jul 29, 2003 05:15 PM
Zaphod 350z
Nov 12, 2002 10:12 PM
