Camshaft Position Sensor A
Old Nov 13, 2007 | 06:38 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
any resolution here? i need to fix my p0340 code as well. Ive got the cam a code. So when you guys say right hand side, you mean the sensor on the right side as your looking into the engine bay from the front ( drivers side in the US)?
Old Nov 13, 2007 | 07:20 PM
amai21's Avatar
amai21
Both should be replaced. That was part of the recall.
Old Nov 14, 2007 | 04:36 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
now to see if my baby gets it done for free:
Recall Date:
NOV 17, 2003
Model Affected:
2003 NISSAN 350Z
Summary:
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence:
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE CRANK POSITION SENSORS. CAMSHAFT POSITION SENSOR(S), AND IN SOME CASES, THE VARIABLE TIMING CONTROL SENSOR(S). VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Potential Units Affected:
630000
Notes:
NISSAN NORTH AMERICA, INC. R3021/R3022
Old Nov 14, 2007 | 04:45 AM
reptile718's Avatar
reptile718
Where you guys experiencing high idle when this problem was occurring?
Old Nov 14, 2007 | 05:00 AM
amai21's Avatar
amai21
The engine will rough idle and shut down at higher rpms......
Old Nov 20, 2007 | 12:55 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what finally fixed your problem?
I replaced my sensor and it didnt fix the issue. The car died on me this morning but then worked fine for about 1.5 hr of continuous use. All lights in my dash are on and i got the code repulled. Still getting a po340.
Old Nov 20, 2007 | 01:20 PM
ssc's Avatar
ssc
i had the same problem on my 05...car started jerking and shut down on the freeway
Old Nov 20, 2007 | 03:38 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what did they do to fix it?
Old Nov 21, 2007 | 06:23 AM
amai21's Avatar
amai21
I had the same problem, but I did a reset from my code reader and it was back to normal
Old Nov 21, 2007 | 06:25 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
think the foot pedal reset is the same? I did that and the issue came back. Thinking about removing the battery for a day or two.
Old Nov 21, 2007 | 06:29 AM
amai21's Avatar
amai21
I believe it wouldnt be the same. Keep in mind some of the local auto part stored will do it for free (Autozone)
Old Nov 21, 2007 | 12:30 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
replaced the actual bank 1 sensor...........everything seems good. I crank it 4 times and the code did not come back.
Going to go for a ride and see if the code pops up again.
Old Nov 25, 2007 | 12:51 PM
ssc's Avatar
ssc
the dealer replaced the sensor and its been good for the past six months..but the car started jerking again few days ago! im pretty pissed. thinking about selling the car now. very disappointing
Old Jan 16, 2008 | 06:30 PM
ryan350z's Avatar
ryan350z
Ever get it fixxed?? Anyone ever find there problem? I been gettting this code off and on since I installed my new motor.
Ryan
Old Jan 16, 2008 | 06:58 PM
amai21's Avatar
amai21
I replaced both(driver and passenger) side and everything has been great so far (knocking on wood)....
Old Sep 11, 2008 | 11:30 AM
scotts300's Avatar
scotts300
P0340 visited me when we rolled 60,100 miles. The sensor is $58, but I'm headed to the dealership to insist it be replaced from the recall.
Old Sep 15, 2008 | 10:50 AM
ADMAN's Avatar
ADMAN
Updates???
Old Sep 15, 2008 | 10:57 AM
  #38
Jay'Z's Avatar
Jay'Z
You must have a bad sensor ADMAN.. Which one?
Old Sep 15, 2008 | 10:58 AM
  #39
scotts300's Avatar
scotts300
Dealership said my 9/03 production 04' was not covered under the recall. Funny thing is that the tech who greeted me - and attempted to help me - said he knew nothing about any 03' sensor recall. I informed him the recall number, and reiterated that 630,0000 03' Nissan vehicles were recalled, and promptly asked for a senior technician.
We got the right part, and after wrestling with the clip on the sensor for a while, all is good now. I'm still not convinced that there was a special "basket" of "new" connectors for the 04' Z33s, as there were 04' models included in the second round of recalls on that same sensor. For $60, it wasn't worth me arguing about it and having the car continue to run like *** and strand me - or worse yet - my wife, while running errands. Once the car is warmed up, it's a bear to start again after shutting it off.
Enjoy,
SS
Old Sep 15, 2008 | 11:00 AM
  #40
scotts300's Avatar
scotts300
If it's the Cam Angle Sensor, "bank 1", it's PN 23731-6J90B "Sensor Assy".
