Crank Pulley and Lightweight pullies not making a difference in performance?
Old Nov 21, 2005 | 06:25 PM
Diesel350's Avatar
Diesel350
Default Crank Pulley and Lightweight pullies not making a difference in performance?
I keep seeing dyno's especially for the Crank Pullies showing no gain whatsoever.
It does make your revs quicker but I have yet to see someone show proof of better 1/4 mile times after a crank pulley or Lightweight pulley install.
Old Nov 21, 2005 | 06:34 PM
GEE PASTA's Avatar
GEE PASTA
Its because it kills drivability. Less flywheel mass.
Old Nov 21, 2005 | 06:46 PM
DavesZ#3's Avatar
DavesZ#3
You're thinking of the lightweight flywheel, not an engine pulley.
Old Nov 21, 2005 | 06:48 PM
DavesZ#3's Avatar
DavesZ#3
How much will your 1/4 mile drop with an additional 5 to 10 hp?
How many drivers are consistant enough so that they'd notice an improvement of a few hundreds of a second?
Old Nov 21, 2005 | 06:55 PM
Diesel350's Avatar
Diesel350
I haven't seen any dyno's showing gains of 5hp much less 10 hp for a flywheel or crank pulley. All I have seen are no gains or losses. Here someone who posted a recent dyno after a KJR Pulley install.
Attached Thumbnails Crank Pulley and Lightweight pullies not making a difference in performance?-pulley3.jpg
Old Nov 21, 2005 | 07:28 PM
screener's Avatar
screener
Most mods stayin N/A will not give much hp when by themself, but bolt on a few things and gain some 10-15hp.Now it is only a lighter pully so I would of and never expected much.But I felt a better response in power from the UD pully than my HF cats(most likely cause the pully starts out making the power and my *** can't feel the HF cats making power up top).Low E.T.'s are nice but I tend to watch the trap speed more.Dyno's are not the final answer to if a mod made power.From what I have heard from Stillen the 350Z will lose power when you run hotter coolant temps.So is the guy running the dyno letting the car cool to the exact coolant temps each time he visits to make some pulls?Just some food for thought.
Old Nov 21, 2005 | 09:13 PM
GEE PASTA's Avatar
GEE PASTA
Sorry!! Im not thinking! I know, The pullies are just a joke on what they do to a VQ.bolt on a fluidamper and open the window for true hoursepower.
Old Nov 21, 2005 | 09:15 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
this is what we got from just the addition of a UR Crank pulley on a car with NISMO Intake, NISMO Cams, NISMO Headers, High Flow Cats and NISMO Exhaust and then adding the crank pulley...
Old Nov 21, 2005 | 09:18 PM
ReavTek's Avatar
ReavTek
I'm not sure about HP gains but the pulleys made a HUGE difference in the response of the car. Exhaust and intake weren't nearly as noticable, makes me wanna pick up a flywheel soon also.
Old Nov 21, 2005 | 09:26 PM
GEE PASTA's Avatar
GEE PASTA
Jason
Just one more of your BS posts. Come on buddy!! Tell how much power it makes, No f--king way, Your information is so bad. Sorry I forgot you sell parts for a living. I got a set of pullies i will sell you cheap. Put them on your car. Pasta
Old Nov 21, 2005 | 10:25 PM
Jason@Performance
Performance Nissan
Jason
Ok buddy...
That car was Jeff's Car... All that was done was raise the rev limiter with technosqure, they couldnt tune it because it was an 04 at the time and it made that power...
Do I have to get another stock Z and put the crank pulley on it so you see the power it makes?
Even if it made only a couple of horse power it actually makes horse power all the time...
As well as add's better engine response...
Old Nov 21, 2005 | 10:28 PM
Jason@Performance
Performance Nissan
I have told many people about parts that do not make power for their car and recomend them not buying them... Even if they are ready to give me the money I tell them its not worth it...
I am probably one of the few people who will turn down a sale to keep from selling crap...
I am a car lover first before selling parts... I try to recomend the best parts to make the most power...
The UR pulley does make power across the full RPM range...
The 2 accessory pulley,s dont waste your money on those... they are only a few grams lighter then the stock pulley's and offer NO power gain...
The crank pulley makes power... Our race team was skeptical of them as well until they actually tested them... Now they are on all of the race motors they built...
want to race?
Old Nov 21, 2005 | 10:44 PM
dxgary77's Avatar
dxgary77
light weight pully will not add top end power. it does freeup hp at low end. i felt the car rev smoother after adding the pully. i used to felt that car was really heavy especially at lower rpm. after i got the pully i didn't wait to get my jwt flywheel. those two made my z feels much lighter. in fact, lightweight pully is not a good mod for drag. i will recommend it to those who go to track often.
Old Nov 21, 2005 | 11:14 PM
Jason@Performance
Performance Nissan
maybe when used with a 16lbs flywheel and clutch on the other end of the crank it magnifies the effect of the UR pulley...
Old Nov 22, 2005 | 12:31 AM
Mike Wazowski's Avatar
Mike Wazowski
Jason
I was going to get into it here, but I figure you are not worth the time.
Old Nov 22, 2005 | 06:30 AM
thawk408's Avatar
thawk408
Isnt the KJR the same size diameter as stock just lighter weight and the UR is an actual underdrive pulley?
Old Nov 22, 2005 | 06:32 AM
Mike Wazowski
that is correct.
Old Nov 22, 2005 | 06:37 AM
thawk408's Avatar
thawk408
That is probably why the KJR doesnt do anything and the UR does.
Old Nov 22, 2005 | 06:44 AM
Mike Wazowski
KJR should free up HP also, just not anything dramatic. There is a formula somehwere that explains that every pound saved on the crank pulley = HP increase (not sure of the number and do not want to quote incorrect info).
Old Nov 22, 2005 | 06:53 AM
cvt's Avatar
cvt
really??? wow...i was about to buy a KJR too...
