6MT Transmission Fluid: GL-4 or GL-5
Old Nov 23, 2005 | 01:19 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Default 6MT Transmission Fluid: GL-4 or GL-5
(I tried searching for this and transmission fluild but did not get any info I needed, so I'm posting.)
For all of you who has replaced your 6MT tranny fluid or know about this subject:
1) Is it OK to use API GL-5 75w-90 on the tranny and differential? (Mobil 1 sys)
2) What is the difference between API GL-4 and GL-5?
The instruction manual says API GL-4 75w-85/90 for the tranny and API GL-5 80w-90 for the differential, but I could not find any GL-4
Need help quick...
Old Nov 23, 2005 | 02:02 PM
g356gear's Avatar
g356gear
I use synthetic 75w-90 GL-5 in the tranny and differential. I swapped out the tranny oil when the car was brand new and haven't had any issues.... no grinding, no notchiness....perfect.
Old Nov 23, 2005 | 02:21 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Thanks g356gear.
I did more search for Gl-4/5 and know the difference between them.
Old Nov 23, 2005 | 03:44 PM
homiusang's Avatar
homiusang
A lot of people said GL5 is corrosive to the syncros and not to use that rating for tranny oil. I also had a hard time finding GL4 tranny oil so I went with GL5 Royal Purple instead, both tranny and differential. Tranny *feel* a bit more smooth and less notchy, but not by much.
Old Nov 23, 2005 | 07:50 PM
esfand's Avatar
esfand
Originally Posted by Tenac1ousZ
Thanks g356gear.
so what is the difference between them??
Old Nov 23, 2005 | 10:03 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Based on what I've read, API GL-5 has special additives that allow it to outperform GL-4 (not sure in heat/friction or etc), but because of the added chemicals, it is NOT good for transmissions which use copper synchros -- such as the Z/G's. Doing so will cause premature corrotion in the "yellow metal."
The dealer's OEM tranny fluid costs $17 a qt. and the Z's tranny uses a few qts. (not exactly sure how many).
Old Nov 23, 2005 | 11:08 PM
Monsta's Avatar
Monsta
This thread may help.
Old Nov 24, 2005 | 02:20 AM
Tenac1ousZ's Avatar
Tenac1ousZ
Thanks a lot Monsta, that really made everything much clearer!! You da man.
Old Nov 24, 2005 | 06:53 AM
Z PHAT Z's Avatar
Z PHAT Z
I'm using Amsoil GL4.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
