Plenum polishing questions
Old Nov 26, 2005 | 10:27 AM
cantfindaname's Avatar
cantfindaname
Default Plenum polishing questions
I have removed the plenum and have started the process of polishing it. I have searched and searched for a DIY on this, but am pretty much just going at it by trial and error. So far, I don't believe I have made any errors, but there is one thing that is questionable for me at this point.
Once I am finished, and am ready to put the plenum back on, should I use sealant around the gasket? Or should I just put it back on without using any sealant.
If I am supposed to seal it, would this work? "Permatex Sensor-Safe Ultra Copper High Temp RTV Silicone."
Old Nov 26, 2005 | 11:40 AM
Mike Wazowski's Avatar
Mike Wazowski
I would buy a new gasket.
Old Nov 26, 2005 | 12:21 PM
DavesZ#3's Avatar
DavesZ#3
Most people reuse the factory gasket. If you don't feel comfortable, get a new factory one. I wouldn't fool with the liquid gasket stuff myself.
When you give up on the polishing let me know and I'll give you the name of a guy that does it reasonably cheap.
I attempted it a while back and figured out that I'd spend more on equipment and polishes than what I could pay an expert to do it for.
Here is some info I came across if you are set on trying it yourself....
http://www.z31.com/repairs/polishfaq.shtml
http://robrobinette.com/polish.htm
http://www.caswellplating.com/buffs/alpolkit.htm
Google "aluminum polishing" and you'll find a bunch of stuff....
Old Nov 26, 2005 | 12:30 PM
MySunset350Z's Avatar
MySunset350Z
so who's the guy that will do it for a reasonable price? lol. i was going to make a project out of it during the few days i have off, but i just might have this person do it if the price is right.
Old Nov 27, 2005 | 09:39 AM
Quamen's Avatar
Quamen
i did mine by hand. took me forever. but looks good
www.putfile.com/quamen
Quamen's Avatar
Quamen
just reused stock gasket (nothing wrong with it) and I have FI.
Old Nov 27, 2005 | 09:49 AM
MySunset350Z
thanks for the info Dave.
looks real nice quamen.
Old Nov 27, 2005 | 01:59 PM
E K's Avatar
E K
I used the stuff from caswell plating.
The good part, is that once you have the materials, you can polish all sorts of stuff for the car.
Here's a pic of a TSX projector mounted onto the stock G35 reflector. The shroud is polished tin sheets.
Old Nov 27, 2005 | 02:35 PM
03znj's Avatar
03znj
Know it all
the plenum is aluminum?
Old Nov 27, 2005 | 03:21 PM
DavesZ#3's Avatar
DavesZ#3
Yes, sand cast aluminum. The sand casting make it very rough requiring a lot of grinding or sanding to get it smooth enough to start the polishing process.
Old Nov 27, 2005 | 07:56 PM
03znj's Avatar
03znj
Know it all
Can it be anodized?
Old Nov 28, 2005 | 03:54 AM
DavesZ#3's Avatar
DavesZ#3
I don't see why not. I've seen pictures of people that have gotten them powdercoated.
Old Dec 2, 2005 | 06:12 AM
one3502nv's Avatar
one3502nv
I have one for $225 shipped + your stock one if you want... Professionally polished and looks like chrome.. email me @ jays350z@aol.com if you are interested... I also have a polished TB for $125 + your stock one if you want...
