Pulley install question
Old Dec 1, 2005 | 07:19 AM
03_Track_Z's Avatar
03_Track_Z
Default Pulley install question
I have no idea what people mean when they say "torque it to 36lbs +60degrees which equals 90-110lbs"
I thought you just put the pulley on there and turn the socket wrench as hard as freaking possible? How do you know how many ft/lbs of torque you you are tightening with? Thanks.
Old Dec 1, 2005 | 08:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I used my breaker bar to tighten my CP to what I felt was acceptable I know its not by the book but Ive had it for 30+ miles (15 or so with a 7100rpm redline) with no issues.
Old Dec 1, 2005 | 08:12 AM
Mike Wazowski's Avatar
Mike Wazowski
use a torque wrench
Old Dec 1, 2005 | 09:02 AM
screener's Avatar
screener
The torque is more than 110ftlbs.You will first torque to 30ftlbs then make a mark on the pully at 1 of the lines on the bolt,then tighten till the mark you made on pully lines up with the next factory line on the crank bolt.
Old Dec 1, 2005 | 10:30 PM
ARLETOS 350Z's Avatar
ARLETOS 350Z
Because i am the only one in earth that hase change motor to 3.500klm due to loose pully bolt(the oem pully-the factory) i would suggest to torque to the the limit with an airgun and using some Locktight glue
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
