how do u know when u need a new tranny?
Old Dec 7, 2005 | 08:14 PM
NDT802's Avatar
NDT802
Default how do u know when u need a new tranny?
How do u knwo when u need a new tranny or a clutch?
Old Dec 7, 2005 | 08:43 PM
bamyi's Avatar
bamyi
When its grinding, feels notchy, tacty or just doesn't sound right.
Old Dec 7, 2005 | 09:58 PM
MovingViolation's Avatar
MovingViolation
Is the tranny covered under the 3yr or the 5yr powertrain warranty?
Old Dec 7, 2005 | 10:40 PM
MeetJoeAsian's Avatar
MeetJoeAsian
a buddy of mine told me he'll change out my tranny and clutch for me under warranty...whoo hoo....and my tranny is still good....except when I downshift from 6-5...GRRRRIND..
Old Dec 8, 2005 | 02:45 PM
A_16's Avatar
A_16
is this tranny supposed to be silky smooth, mine is quite notchy, but doesnt grind or anything unusual, whines a bit but ya
Old Dec 8, 2005 | 03:06 PM
ANXIOUZ's Avatar
ANXIOUZ
No, it's nowhere near silky. It should feel a bit notchy but nothing excessive. And no grinding.
Old Dec 8, 2005 | 03:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
is the 5yr really true? i have an 03 that is notchy/grinding and needs replacement bad! i hope its covered, its got me depressed lately!
Old Dec 8, 2005 | 03:10 PM
halitosis's Avatar
halitosis
+1. Although I was quite worried at first because of the unusual noises it makes. I still grind slightly (more like it catches) on my 1st to 2nd shift when, cold especially. I hear higher viscosity tranny fluid (Royal Purple notably) helps the situation.
Old Dec 8, 2005 | 03:12 PM
MagicPie's Avatar
MagicPie
Powertrain is 5Yrs 60,000 miles
Old Dec 8, 2005 | 03:15 PM
ANXIOUZ's Avatar
ANXIOUZ
Yeah, once things warm up it all gets smoother for me. I don't grind, but I it does catch going 5th-6th for me on occassion.
And yes, it's a noisy SOB.
Old Dec 8, 2005 | 03:16 PM
MagicPie's Avatar
MagicPie
I recently change tranny/diff oil to syth. RoyalPurple Max Gear, It could all be in my head but it feels alot better. I didnt have any previous problems (grinding, notchy, rough) but the nissan manual show to change tranny/diff oil around 36K am around 31K
Old Dec 8, 2005 | 03:19 PM
If you push in the clutch, but it does NOT disengage, you need a new clutch.
If the drive shaft does not turn, you need a new transmission.
Old Dec 8, 2005 | 03:26 PM
350Z007's Avatar
350Z007
Mine catches going from 1st to 2nd when cold. I have to hold the clutch and wait a second before going into 2nd to avoid this. Once I drive a few miles it stops. I'm scared this will get worse.
Old Dec 8, 2005 | 03:32 PM
HarvesterUT's Avatar
HarvesterUT
Originally Posted by 350Z007
Mine catches going from 1st to 2nd when cold. Once I drive a few miles it stops. I'm scared this will get worse.
when i fire her up on a cold night/day my 1st-2nd shifts are TERRIBLE. its been like this since day one. i wouldnt worry about it. once the tranny heats up it gets rather smooth. now if you hear a nasty grinding sound when you select a new gear with the clutch depresssed....its time for a new tranny
Old Dec 8, 2005 | 06:24 PM
dragon11689's Avatar
dragon11689
My first to second shift. I still hate the way it shifts. There is no way this is a sports car if it keeps up like that. Corollas are passing me because I have to shift so hard to get it into second quick otherwise I have to shift slowly so it goes in smoothly. Any ideas why this is happening? Is this normal? Is that what you guys mean by notchiness?
Old Dec 8, 2005 | 06:45 PM
NDT802's Avatar
NDT802
Default yea
i have that same problem
Old Dec 8, 2005 | 08:57 PM
dragon11689
I feel ya man. I think I'm going to go to a different dealer to check this out. The first one didnt seem to see a problem with it. Then again that dealer sux anyway. I hope I get some good feed back on why this is happening from a good source.
Old Dec 9, 2005 | 04:15 AM
350Z007's Avatar
350Z007
Yeah, with mine if I don't go slow into second especially when it's still cold it will grind on me. I only have 900 miles on my car too. This really sucks!
Old Dec 9, 2005 | 07:33 AM
Never Mind's Avatar
Never Mind
excuse my ignorance, but when you say "grind" what do you mean?
sorry, but I am not native english and the dicitonay didn't help much..
