fuel line pressure release
Old Dec 15, 2005 | 12:14 AM
zeer0's Avatar
zeer0
Default fuel line pressure release
Hi guys, I need some help. Does anyone know how to release the pressure from the fuel lines? If so, please reply, i'm stuck in the middle of an install
Old Dec 15, 2005 | 01:49 AM
atlsupdawg#2's Avatar
atlsupdawg#2
Pull the fuel pump fuse and then start the car. Let it run until it stalls then crank it over 2 to 3 times to evacuate the residual fuel. This is per the service manual when not using the Consult II tool.
Old Dec 15, 2005 | 01:52 AM
atlsupdawg#2
Damn, disregarded the part about you being in the middle of an install so I don't know if you'll be able to start the car or not. If not someone else may chime in on best method. You may just have to slowly crack a line open and let the gas drain in bucket..
Old Dec 15, 2005 | 02:32 AM
Barzten1's Avatar
Barzten1
This is off topic but I recently noticed my fuel pressure guage which usually reads 51 not reads 50. Temps are really getting cold around here. Are they a related issue? Should I worry?
Old Dec 15, 2005 | 03:53 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is precisely correct. The fuel pump fuse is located in the engine bay, BEHIND the battery, so you have to remove the plastic trim piece near the windshield.
If you cant crank the car over in its current state, then just gradually loosen up the fuel line from the rail (two 10mm bolts), and have a rag handy. It will drip some fuel, but it shouldnt be too terriblly bad, as long as you are ready for it.
EnjukuRacing
Sep 30, 2015 06:55 AM
