No more 350evo "Monopoly" on Gears?
Old Dec 22, 2005 | 01:01 AM
GAaaAR's Avatar
GAaaAR
I know it says for 6mt only. But what if i have the mt pumpkin and just swap the gears and install it on my 5at?? Would it work? I know for a fact the 350 evo 3.9 fd works as long as i have the mt pumpkin.it shoudl make sense that these will as well right?
Old Dec 22, 2005 | 04:17 AM
palepony's Avatar
palepony
Z1
Is the ring gear the same thickness as stock? I want to mate this to the quaife ATB LSD.
thanks
pp
Old Dec 22, 2005 | 05:33 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by 350ZNV
I think 350evo is getting out of the 350Z market aren't they?
Yes, and maybe no. They are probably not going to make any new products, but if the demand stays there for the current products they do have available, they might keep selling that stuff
Old Dec 22, 2005 | 05:50 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
In order to use this, you need a 6MT pumpkin and the assoicated parts needed to make it all work together - having never done this before, I cannot comment on what exactly is needed to make it work. As far as bearings go, they are a wear item, so it is at the users (or preferably the installers) discretion as to whether or not they replace them. Since I am not an expert in bearing construction or life, I'll defer to your installer to tell you if you should do them or not. When I did my own gears, I had arond 18k miles on the car - I did not replace any of the bearings as none of them needed replacement.
As for the quality of the units, again, the first batch is arriving any day, so I have not seen them first hand. However, Central 20 is an OLD company in Japan, with a 30 year history of modifying and racing Z's
I cannot comment on the stock ring gear thickness as I don't have one to look at (my installer accidentally tossed mine away when my ring and pinion was installed) but I don't see why/how it could be any different. As for compatibility with the Quaife, since we chose to not sell the Quaife differential for the Z, you'll be on your own there. I made sure to check prior to deciding to carry these if this ring and pinion would work with the LSD's we offer (NISMO, Cusco, ATS), and was informed by Central 20 all of these, as well as the stock viscous LSD, are compatible.
Also, we can do a package deal with the ring and pinion and LSD, but are not going to offer any "preassembled" packages with pumpkins, etc - simply too time consuming.
Old Dec 22, 2005 | 05:55 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sorry if I posted this too soon Adam.
Central 20 is definitely old skool JDM and if the parts fit ther other LSD's as mentioned, I think it is safe to say that it fits the other LSD's. Disclaimer: Coming from me and not Z1
Old Dec 22, 2005 | 06:28 AM
Lawn Dart's Avatar
Lawn Dart
It's about time, 240sx ring & pinion sets go for about $450.
Old Dec 22, 2005 | 09:06 AM
Z1 Performance
Former Sponsor
OK - install kits are now posted on the site as well. We offer 2 types of kits. The first includes all the mandatory parts (with the exception of the side adjustment shims since they are install specific). For those who also want to replace all the bearings and bolts, we offer those as well
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1726
Old Dec 24, 2005 | 02:05 PM
Z1 Performance
Former Sponsor
these are now instock, and we will begin shipping on Tuesday!!!
https://my350z.com/forum/showthread....80#post1954880
Old Dec 24, 2005 | 03:42 PM
Anomaly460's Avatar
Anomaly460
About how many units do (or did) you have in stock and do you have any time frame on when the next batch is coming?
Old Dec 25, 2005 | 08:01 AM
Z1 Performance
Former Sponsor
out of this batch that just came in, there are now 4 left. I have no idea about timing on the next round, as its up to how fast Centeal 20 produces them. Like most parts from boutique manufacturers in Japan, they are made in pretty low volumes
Old Dec 25, 2005 | 01:30 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is great!
FYI: Since these gears work on the ATS, Cusco, etc...LSD's, it will work on the Quaife as well, assuming you have the Quaife properly installed with the spacer plate/bolts.
Old Dec 25, 2005 | 07:55 PM
Z1 Performance
Former Sponsor
good to know Sharif, thanks - have had a few people asking about compatibility.
Down to just a handful now guys
Old Dec 25, 2005 | 08:21 PM
nosser's Avatar
nosser
what's the install cost for this and where are the competent installers in the socal area?
Old Dec 25, 2005 | 09:42 PM
Z1 Performance
Former Sponsor
install usually runs around $400 or so from most everyplace I have heard of. As for socal, best bet is probably to ask some people in that regional forum
Old Dec 26, 2005 | 07:43 AM
BlueMeany's Avatar
BlueMeany
once we dtermine the size of the shims, where do we get those from??
Old Dec 26, 2005 | 07:45 AM
Z1 Performance
Former Sponsor
BlueMeany - the shims are offered at your local dealer.
Old Dec 27, 2005 | 04:12 PM
Z1 Performance
Former Sponsor
Just a quick note...we unwrapped these today and shipped out the several units that were sold over the weekend. As expected, the quality was impecable. Every ring and pinion set is shipped as a matched set, and the machining was flawless - no burs, nor imperfections of any kind. If you are looking for a 3.9 R&P, these simple can't be beat
Adam
Old Dec 27, 2005 | 05:09 PM
  #38
LOU's Avatar
LOU
I have a 6MT, but swapped pumpkins with a 5AT for better driveability when I went FI. Does this mean I can't use this 3.9 FD? I didn't notice a difference with the pumpkins when we swapped.
Lou
Old Dec 27, 2005 | 05:10 PM
  #39
Z1 Performance
Former Sponsor
as mentioned, I have no idea, sorry
Old Dec 27, 2005 | 05:15 PM
  #40
LOU's Avatar
LOU
Hmmm... Okay, I'll try to find out...
