Aftermarket Flywheel :help:
Old Dec 23, 2005 | 07:17 PM
Zilvia's Avatar
Zilvia
Default Aftermarket Flywheel :help:
what gains would be had from swiching out the oem fly for an aftermarket flywheel on a turbo car............is it worth the money to just buy a fly wheel or wait for the clutch to go out and buy both a new clutch & flywheel at the same time?
Old Dec 23, 2005 | 08:18 PM
hndumafia's Avatar
hndumafia
if you consider the installation cost, which is like $400, it makes much more sense to install the clutch and flywheel at the same time.
Old Dec 23, 2005 | 08:32 PM
westpak's Avatar
westpak
SFZCC
As mentioned if you have plans to do both you should do them at the same time.
As for the need for a flywheel with TT, not really, the engine will rev up fast enough when boost kicks in.
Old Dec 23, 2005 | 10:56 PM
Zilvia's Avatar
Zilvia
so just buy the clutch when it goes out then.................how long should the OEM one last after install of twins? is the JWT clutch good for Twins?
Old Dec 24, 2005 | 06:44 AM
westpak's Avatar
westpak
SFZCC
Depends on the driver, mine was replaced at 30k total miles and 10k of them with TT's and looked good and probably good for another 10k.
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
