Boring Out My 350Z'S Cylinder Heads for Better Performance, Pros/Cons?
Old Jan 10, 2003 | 01:38 PM
cadeslade's Avatar
cadeslade
Talking Boring Out My 350Z'S Cylinders for Better Performance, Pros/Cons?
Old Jan 10, 2003 | 01:56 PM
cadeslade's Avatar
cadeslade
A 3.8 L Kit, but we got a 3.5 Lin our Z's, please describe what exactly this kit consists of?
Old Jan 10, 2003 | 02:00 PM
jeffw's Avatar
jeffw
If you bore out your engine from 3.5 to 3.8 you'll need new pistons, oil rings, cylinder sleeves, etc. I imagine that's what the kit consists of.
Jeff
Old Jan 10, 2003 | 02:03 PM
Marv1000's Avatar
Marv1000
Jeff
Exactly.
I thought I read somewhere that the VQ35 is just a bored out VQ30, though?? Is that true?
If that's the case, there's only so much you can bore a given engine.
If not ... woohoo!
Old Jan 10, 2003 | 02:25 PM
DrCold's Avatar
DrCold
could it be a stroker kit? doesnt seem like its that much of a kit (be it stroke or bore).
-DrCold
Old Jan 10, 2003 | 03:12 PM
teh215's Avatar
teh215
From the posts that I have read, it seems like a new ECU must be part of any improvement. As for cylinder heads, Extrude Home usually can work wonders with any stock head or lower intake manifold and can be done "at home".
Old Jan 10, 2003 | 03:43 PM
cadeslade's Avatar
cadeslade
That Kit, where can I find it, any website for it?
Old Jan 10, 2003 | 11:02 PM
apex locator's Avatar
apex locator
-DrCold
i agree, sounds like a stroker kit. there arent any "bore" kits that i've heard of, since its just a complete rebuild of the shortblock.
Old Jan 11, 2003 | 06:13 AM
TonyZXT's Avatar
TonyZXT
Being that the VQ35 is already a much bored out version of another engine it seems more likely that the kit consists of a stroker crank, and maybe different rods. This will give more a little more HP (due to more displacement) and quite a bit more torque (from the larger stroke). The torque curve may even move substantially lower in the rev-band. I'm not sure this is an ideal mod for a sports car, unless the new crank is lighter than stock, because the redline may end up being a little lower, with a larger, heavier crank. Now if you knife-edge this new crank and then balance the whole assembly, and take any extra weight off the flywheel while you're at it and you may have something. Gee, can you tell I'm a HP nut???
teh215, please tell me you were kidding in your post about extrude hoNe. The machine they use costs several hundred thousand dollars, and probably would not fit in your home. C'mon now some newbie prolly took that seriously.
Old Jan 11, 2003 | 10:35 AM
MardiGrasMax's Avatar
MardiGrasMax
If not ... woohoo!
Its not "a bored out version" per say, it just has a larger bore. The cylinder walls of a VQ35 are as thick as a VQ30. Either way you cant bore a VQ more than 0.020" over per the FSM, and thats a trivial ammount. My bet is a stroker crank. Yummy, a 3.8L SC 4th gen Maxima
VQRacer please share some info if you have details!
Old Jan 12, 2003 | 07:46 AM
n3985's Avatar
n3985
Impul ECU:
http://www.impul.co.jp/shop/z33.kaihatu.htm
And te 3.75 stroker kit will make approx. 315.62HP
http://www.impul.co.jp/shop/z33.index.htm
Old Jan 12, 2003 | 02:21 PM
cadeslade's Avatar
cadeslade
That Site ya listed, that's cool, but the only problem is it's in all Mandarin, How would you Order? An English Language site Available, perhaps?
Old Jan 12, 2003 | 02:22 PM
MardiGrasMax
Yes, which US companies are IMPUL dealers?
Old Jan 12, 2003 | 04:51 PM
n3985's Avatar
n3985
You can order by contacting them.
Old Jan 12, 2003 | 05:17 PM
cadeslade's Avatar
cadeslade
Default Since I have A SportTronic Tranny what sort of Mods can I do?
Old Jan 12, 2003 | 05:44 PM
Nealoc187's Avatar
Nealoc187
Hmmm, this kit in a VQ35 shortblock with VQ30 heads, MEVI, JWT Cams and JWT ECU could make for a very interesting motor swap for the maxima... 350hp = not too shabby
Old Jan 12, 2003 | 05:48 PM
n3985's Avatar
n3985
Why not just a VQ30DETT with an upgraded turbo kit?
Old Jan 13, 2003 | 11:53 AM
menehune's Avatar
menehune
I wonder what is the difference in Combustion Chamber CC and valve sizes with the VQ engines. If the VQ30 heads bolt on to the VQ35 short block and the valve sizes are the same, were talking some noticeable cylinder compression increases and power increases. I wonder if the stock ECU wouldn't mind if you bolt on a pair of VQ30 heads?
Old Sep 19, 2003 | 01:54 PM
HNE's Avatar
HNE
Running low compression pistons in the 35 short block would still yield about an 11:1 compression due to the 30 heads. My guess is that you'd get more than 350 HP. Maybe closer to 400. A high compression stroker 350Z with cams is sure to gain more than 60 horses. Thats essentially what you'd have. I definately agree though. Sounds very interesting.
David.
Old Apr 25, 2004 | 10:10 AM
Street Visionz, Inc.'s Avatar
so has anyone confirmed or tried swapping in the VQ30 head onto a vq35 block? Does the head flow nearly as well as the vq35 head? How about getting the vq30 head ported and polished, then would it flow better than the vq35 head?
