No oil? where did it go?
Old Jan 25, 2006 | 09:34 PM
  #41
Z BOY's Avatar
Z BOY
i had my engine replaced due to oil consumption prior to going fi. while driving, watch your oil pressure. should not go <15 psi at idle when warmed up. when your oil level gets too low, your pressure will drop below 15 at idle and will jump around wildly under load. then your low oil warning light will come on.
Old Jan 25, 2006 | 09:53 PM
  #42
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
hey toby another way to check for headgasket leak is to pop your radiator cap, as your coolant is flowing past see if you see bubbles. if theres bubbles its a head gasket. not all headgaskets leaks will show up in the oil, they could enter exhaust valve and just burn off, also is your car running hot? as almost always a blown head gasket will mean soaring temps.
Old Jan 26, 2006 | 04:09 AM
  #43
PumpedVA's Avatar
PumpedVA
NO even with only 2 quarts I not hot.
Well "IF" they find nothing wrong with my car and I do have one of those motors that just burn oil I know nissan will not help. So rather that pay a but load of labor to fix my motor (if this can even be fixed) I am just going to buy this one and swap out my parts
Upgraded Shortblock: $3600 + $1000 core - Good up to 750 Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/*ceramic coating
*Pauter Rods
ARP Rod Bolts
*CP Pistons .020 over(8.5:1 or 11.5:1)
Old Jan 26, 2006 | 11:03 AM
  #44
PumpedVA's Avatar
PumpedVA
well back from AAM took 2 hours both ways checked my oil before I pulled out this mornning and then again at AAM oil level was fine and prressure stayed at 60psi .
Old Jan 26, 2006 | 06:29 PM
  #45
Netko350Z's Avatar
Netko350Z
Funny thing was last summer I only drove my z about 2k miles. My level dropped about 1 qt after about the first 1k. Looks like I am going to keep a close eye on my level this spring.
04 ZR here...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
