Nismo cams
Old Jan 27, 2006 | 04:42 PM
scottone928's Avatar
scottone928
Default Nismo cams
Quick question about the nismo cams. Are they worth the money and effort? Thanks.
Old Jan 27, 2006 | 05:23 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
It all depends...
What are you looking at gettign out of your car?
NA / FI application?
etc etc...
Old Jan 27, 2006 | 06:21 PM
steela2110's Avatar
steela2110
NA I would not recommend the NIsmo cams just from my own searching and experiences
Old Jan 27, 2006 | 06:34 PM
Jason@Performance
Performance Nissan
It depends on where you spend most of your time in the power band...
If you are a daily driver who doesnt spend much time in the high RPM's (5K and above) then NISMO cams will do you better for that low end passing power...
If you spend more time in high RPM's, Track / Drag Racing... then cams like JWT
Old Jan 27, 2006 | 06:36 PM
287HP's Avatar
287HP
Great all around street cam! Solid 15 whp peak gain alone!
Old Jan 27, 2006 | 06:46 PM
J3rzeyFlip's Avatar
J3rzeyFlip
i love my nismo cams! Its a good mod. U can definitely feel the torque and power in low,mid, and high rpm!
Old Jan 27, 2006 | 07:08 PM
scottone928
I got a beed on some new ones for $ 575.00. Thanks for the input.
Old Jan 27, 2006 | 08:09 PM
ZON's Avatar
ZON
Damn!!! Turn that bead into a sale then. Get those puppies now and don't look back!!!! That's a lot of money saved for the install.
But, eh, make sure they are what they say they are.
Old Jan 27, 2006 | 09:18 PM
Dubai's Avatar
Dubai
How much for installing cams? $1000+?
Old Jan 27, 2006 | 09:23 PM
ZON's Avatar
ZON
Nah, I would say 3 to 6 bills depending on where you go.
Old Jan 27, 2006 | 09:24 PM
J3rzeyFlip's Avatar
J3rzeyFlip
a member from this forum did my nismo cams install for $500! Good deal! Local shop was quoting me at $850-900.
Old Jan 28, 2006 | 09:35 PM
laswyguy's Avatar
laswyguy
I got a set of Nismo cams to be installed to0. Are you guys running Nismo's changing your 1)valve springs 2) gaskets?.
thx
laswyguy's Avatar
laswyguy
thx
laswyguy's Avatar
laswyguy
thx
Old Jan 28, 2006 | 10:13 PM
Jason@Performance
Performance Nissan
you must change gaskets and seals
Old Jan 28, 2006 | 10:38 PM
J3rzeyFlip's Avatar
J3rzeyFlip
thx
naw, i kept the stock valve springs but changed the seals. I only had 9k miles on the car before the install.
Old Jan 28, 2006 | 11:30 PM
Jason@Performance
Performance Nissan
If you remove the valves for anything put in new seals.. its cheap enough rather then the labor later on...
http://performancenissanparts.com/ca...oducts_id=1809
$118.95 for the gasket kit when doing the cams only..
If doing your valves / springs etc... its best to get the valve re-grind kit since it includes the head gaskets and valve seals...
http://performancenissanparts.com/ca...oducts_id=2687
nanotech
Oct 2, 2015 05:02 AM
