Need help regarding Wideband AFR Sensors and Gauges.
Old Feb 26, 2006 | 11:47 PM
Havok_RLS2's Avatar
Havok_RLS2
Default Need help regarding Wideband AFR Sensors and Gauges.
Hey guys. I need some input regarding purchasing and installing Wideband AFR Sensors and Gauges. I have the following questions.
1. Which ones are the best on the market?
2. Do I have to change out my stock O2 sensors?
3. Is this an easy install for a mid-level tuner with a background in wiring and electronics?
4. Will I need to purchase more than one due to the fact the our cars are equiped with one 02 sensor on each side of the engine?
5. Does anyone have or used the PLX R500 Wideband Sensor with data logging and is it worth the money?
I'm asking these question because as I start modding the engine more it seems like a good investment to know what my motor is doing on the daily before and after tuning. Since a lot of you guys have already gone FI, I figured most of you should already have these installed already.
The only thing that I've heard for sure is to stay away from the AEM stuff.
Care to give a fellow member a hand?
Old Feb 27, 2006 | 09:22 AM
superchargedg's Avatar
superchargedg
Damn Noobs
i would also like to know more info on this,and please do not just say search,i have and you dont find out a whole lot of useful info.
Old Feb 27, 2006 | 11:11 AM
UpRev's Avatar
UpRev
Sounds like you should check out Cipher.
http://www.uprev.com/products/cipher_NI.html
Cipher is a Nissan/Infiniti Data and Diagnostic system.
Cipher does not require you to change out your stock O2 sensors. In fact, Cipher will read directly from your 2005 wideband sensors.
As far as install... Cipher only takes a few minutes to install to your laptop and our interface cable plugs directly into your OBDII port. No wiring installation required.
Cipher Functionality Matrix
http://www.uprev.com/text/cipher_fun...ity_matrix.pdf
Let us know if you have any questions.
www.uprev.com
sales@uprev.com
Old Feb 27, 2006 | 01:43 PM
overZealous1's Avatar
overZealous1
you won't need to remove or do anything to the stock 02 sensors. you will need to weld in a new 02 bung though, as all the wideband gauges come with their own 02 sensor. i am running the aem gauge, or should i say was. it just took a turd on me. the innovate w/b is one of the best i hear and i am prolly switching to that. wiring is no more complex than finding a ground and accessory on power supply.
Old Feb 27, 2006 | 01:54 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Most widebands use the same Bousch sensors so it's really up to you on what you like. They are all gonna work about the same. Some have diffent features than others and then of course you have the different looks.
Old Feb 27, 2006 | 06:13 PM
Havok_RLS2's Avatar
Havok_RLS2
Thats good information! Thanks.. Since I have a NISMO catback should I have the new O2 bung welded at the Y pipe? Should the new O2 sensor be placed before the cats or after? Does it matter either way?
Old Feb 27, 2006 | 06:19 PM
Havok_RLS2's Avatar
Havok_RLS2
www.uprev.com
sales@uprev.com
This sound like a really great product that would make a nice addition to my UTEC but I don't wanna have to drive around with my laptop mounted(somehow) in my car all the time. However it's something I'll think about in the future. Thanks.
Old Feb 27, 2006 | 06:28 PM
Havok_RLS2's Avatar
Havok_RLS2
Please guys. The more information we can gather on this subject the better. It seems as though others have had some of these same question. Seaching the forum results in almost nothing but a waste of time and more confusion. So if you have some rgood information to share please do.
From the way I understand it, anyone who expects to do any kind of modding or tuning on the Z should be considering purchasing good Wideband AFR Sensors and Gauges anyway.
Thanks guys.
Old Feb 27, 2006 | 06:39 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The new 02 sensor goes before the cats
Old Feb 27, 2006 | 06:41 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i love my aem, very easy install, just have to get a bung welded which i had put on before i installed my test pipes
Old Feb 27, 2006 | 07:04 PM
Havok_RLS2's Avatar
Havok_RLS2
Which side for best clearance and readings?
Old Feb 27, 2006 | 07:09 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Drivers
Old Feb 27, 2006 | 10:09 PM
overZealous1
either side will do, but it does need to be before the cats.
Old Feb 27, 2006 | 10:32 PM
ActionJackson's Avatar
ActionJackson
Does the Zerotronix wideband work with a UTEC?
Old Feb 28, 2006 | 04:38 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The drivers side tends to run a little leaner than the pass. That's whay I say drivers.
Old Feb 28, 2006 | 04:42 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
I'm running an AEM and it has helped me a lot with tuning
Old Mar 4, 2006 | 07:03 PM
NISMOFO's Avatar
NISMOFO
I think I might get an innovate gauge as well.
Where can we buy A-pillar mounts that hold 3 gauges?
Old Mar 5, 2006 | 08:59 AM
97supratt's Avatar
97supratt
Now is a wideband completely necessary for N/A vehicles because N/A vehicles dont need to run rich. Can we use the stock o2 sensors for a/f or are they not accurate?
Old Mar 5, 2006 | 10:14 AM
Dissolved's Avatar
Dissolved
Use 2 WB's. One on each side and get a cover for the bungholes in case you don't want to run your WBs 24/7 ( will last longer). AEMs are fine to use
Old Mar 5, 2006 | 12:57 PM
Havok_RLS2's Avatar
Havok_RLS2
HUH?!?!
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
