Anyone using royal purple?
Old Mar 7, 2006 | 01:05 PM
  #41
97supratt's Avatar
97supratt
I took my z for a test drive right after the oil change, at first the oil pressure was higher than normal when it was cold, but it soon warmed up and it was fine.
Old Mar 7, 2006 | 03:42 PM
  #42
fahrenheit350's Avatar
fahrenheit350
97supratt, good to hear on your switch over to synthetic. I also noticed that after switching to Red Line that my oil psi during cold starts (and the next 10 mins of driving) that it was high, close to 110 under accel and 60 idle, but it came down after the engine warmed up. It's normal.
The way I see it.. Amsoil, RL and RP's performance are all relative. I have no doubt that these 3 brands are some of the best you can buy. In the end, my decision came down to price and availability.
**Currently, 2k miles on Red Line 10W30 W/O burning!!!**
Old Mar 7, 2006 | 03:51 PM
  #43
ReV2Red's Avatar
ReV2Red
I haz da turbos
Originally Posted by jakesford
you have that backwards, GL-4 is for the tranny and GL-5 is for the diff....
BTW Royal Purple's Max Gear gear oil complies to both the GL-4 and GL-5 specs...
I use RP for everything...
I stand corrected, i knew it was something like that
Old Mar 7, 2006 | 06:01 PM
  #44
MustGoFastR's Avatar
MustGoFastR
So do any of these fluids in the tranny make shifting noticably smoother? Going high quality synthetic is good for peace of mind and all, but kind of overkill on a daily driven, nin-abused car unless you can really feel a difference, IMO.
Old Mar 7, 2006 | 08:54 PM
  #45
RA11325's Avatar
RA11325
Are you sure you want to put in synthetic at such an early interval? the reduced wear offered by synthetic can have adverse affects on the break in process.
Old Mar 7, 2006 | 10:30 PM
  #46
mikewagon's Avatar
mikewagon
what is this burn off you talk about?
Old Mar 8, 2006 | 06:21 AM
  #47
MustGoFastR
Some Zs consume some oil, some oils more than others. My Z goes through 1 quart of Mobil1 per 5k miles.
Old Mar 8, 2006 | 06:22 AM
  #48
Jay'Z's Avatar
Jay'Z
im using royal purple and after i did...... i felt the difference.... the z felt like a champ i will never go back to mobil 1 in my life unless royal purple goes out of business.. i know all the hype about the purple stuff is true and its worth every penny!! although i recommend getting gallons of that stuff on ebay and doing your own oil changes......
Old Mar 8, 2006 | 03:57 PM
  #49
davidf's Avatar
davidf
So are you still using mobil-1.
Old Mar 10, 2006 | 05:38 PM
  #50
Fa1rLadyZ's Avatar
Fa1rLadyZ
any reason for using 10w30 instead of 5w30??
i used 5w30 for my first oil change
Ace2347
Sep 22, 2015 03:12 AM
mwaller
Jul 9, 2004 09:20 PM
Apexi350z
Jun 25, 2003 03:39 PM
