Turbo VQ30 puts down 429whp
Old Jan 26, 2003 | 05:06 AM
MardiGrasMax's Avatar
MardiGrasMax
Default Turbo VQ30 puts down 429whp
I thought some of you who are going to be turboing your VQ35's would like to see this. 12.5psi
http://forums.maxima.org/showthread....hreadid=184419
Old Jan 26, 2003 | 06:32 AM
ares's Avatar
ares
Veteran
goin out on a limb and saying thats a turboed maxima right? thats some great numbers, however I have a feeling max's are a bit "easier" to turbo. 12.5PSI in the Z and compression would be a problem Id think. or did the max have to have low compression pistons anyway?
Old Jan 26, 2003 | 06:39 AM
MardiGrasMax
Its a stock VQ30DE motor, 10.0:1 CR. Z's VQ35DE has 10.3:1 CR so its not that major of an increase. Cam specs are bigger in the VQ35DE, so dynamic compression would be about equal in the top of the RPM range.
Old Jan 26, 2003 | 09:00 AM
valuetl's Avatar
valuetl
Must be fun trying to put 429 HP on the ground. How bad is the torque steer??
Old Jan 26, 2003 | 09:18 AM
ColecatZ's Avatar
ColecatZ
Man, thats impressive. I just wanted to say Thanks to all the Maxima guys that contribute here as well......It's appreciated.
now, if only I could get forced induction on mine....yummy
Old Jan 26, 2003 | 09:24 AM
iboost's Avatar
iboost
Very impressive numbers.
As mentioned, torque steer must be hellish!
iboost
Old Jan 26, 2003 | 10:06 AM
McDan's Avatar
McDan
What octane are you having to run without detonation?
Old Jan 26, 2003 | 10:20 AM
MardiGrasMax
I cant speak for sure for Nigel, I assume 92 or 93 oct, he's in Colorado so what ever Super Unleaded pup gas istheir, but I run 93 in my SC'd Maxima. Using the J&S Ultra Safeguard to control ignition timing takes the fear of detonation out the picture. Nigel has a J&S I dont know how he has it set. I pull 1 degree of timing per lb of boost starting at 9psi and I peak at ~14-15psi. I am not running an intercooler, Nigel is. The Maxima does have conservative ignition timing from the factory, so I would bet that the Z's VQ35 has more timing advance so it would reguire more timing retard under boost on stock internals with 93oct and/or a good intercooler. I cant believe the stock rods took it, factory shot peening is a good thing I guess.
Old Jan 29, 2003 | 06:01 PM
kaiser23's Avatar
kaiser23
valuetl, you don't get torque steer in RWD cars. It's when you have front wheel drive, and don't have limited slip mostly. One wheel loses traction, and the other pulls hard, and forces the steering to pull to one side.
Old Jan 29, 2003 | 06:08 PM
ksj's Avatar
ksj
I thought the Maxima was FWD...
Old Jan 29, 2003 | 06:26 PM
kaiser23's Avatar
kaiser23
Oh, my bad, it is. I was thinking in terms of the Z. Ignore my previous comment.
I drove a 2003 maxima while my Z was having warranty work done, and it had pretty bad torque steer with the 255 it comes with, so I imagine 429 at the wheels would be pretty aweful.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
