Tightening KJR Pulley on AT
Old Mar 14, 2006 | 09:33 AM
BobaFettm's Avatar
BobaFettm
Default Tightening KJR Pulley on AT
I've did this once... but it seemed to come loose after the TT install...
anyone know how to keep the engine from turning over with the AT and tightening the Crank pulley?
Old Mar 14, 2006 | 12:37 PM
BobaFettm's Avatar
BobaFettm
Old Mar 14, 2006 | 01:25 PM
ken350z's Avatar
ken350z
On the bottom left side (drivers side) of the front of the transmission is a 2" dia plate. Behind the plate you can see the teeth on the flywheel that the starter uses. Stick a big screwdriver in there to jam it and keep it from turning.
Ken
Old Mar 14, 2006 | 05:16 PM
BobaFettm's Avatar
BobaFettm
any possible way to do this other then this method... im in my dorm parking lot... does brake and putting it into gear affect anything?
Old Mar 14, 2006 | 05:29 PM
dream724Z's Avatar
dream724Z
Only if you have a manual. You should tow it to a good shop to install it correctly, or it will get very expensive. Search for bad pulley install posts.
Old Mar 14, 2006 | 06:39 PM
BobaFettm's Avatar
BobaFettm
I'll just take it to Tuning factory... I installed the pulley myself NA... worked GREAT! after the TT... seemed to loosen up!
Old Mar 14, 2006 | 06:45 PM
dream724Z's Avatar
dream724Z
The extra HP/TQ will rattle everything.
Take it easy with that beast!
Old Mar 14, 2006 | 10:24 PM
BobaFettm's Avatar
BobaFettm
was guessing the same thing
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
