Clutch and flywheel performance question
Old Mar 20, 2006 | 03:45 PM
charged's Avatar
charged
Default Clutch and flywheel performance question
I have a s/c roadster and was thinking of adding a JWT clutch flywheel kit. My 0-60 time is not as great as I thought it should be, will a kit like this help?
Old Mar 20, 2006 | 04:55 PM
roast's Avatar
roast
It will help a small amount considering you know how to launch. Wider/stickier rubber will make a bigger difference 0-60/quarter mile. The lighter clutch/fly will make a bigger difference from a roll.
Old Mar 20, 2006 | 05:54 PM
charged's Avatar
charged
What is correct way to launch?
Old Mar 23, 2006 | 11:07 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you want better 0-60 times, clutch and flywheel is not the first place to look...
a lighter clutch and flywheel will help with better acceleration once rolling... but you need to lock up the rear tires first on the ground... with the aggressive negitive camber of a stock 350Z you are not making contact with all the rubber, so wheel spin is easy at any RPM...
once you fix the traction issue, a light weight clutch / flywheel will help with acceleration / faster shifts over all..
Old Apr 4, 2006 | 12:33 PM
charged's Avatar
charged
Any ideas on how to fix the traction issue.
Old Apr 4, 2006 | 12:38 PM
Jason@Performance
Performance Nissan
throttle controll...
less negitive camber in the rear...
Old Apr 5, 2006 | 06:31 PM
charged's Avatar
charged
Throttle controll?
Old Apr 6, 2006 | 12:19 AM
overZealous1's Avatar
overZealous1
Originally Posted by charged
Throttle controll?
don't spin the tires by flooring it too soon
Old Apr 7, 2006 | 10:23 PM
I can't tell the players without a program (need to see some time slips).
Old Apr 8, 2006 | 04:52 PM
infidsg35's Avatar
infidsg35
How do you adjust the negitive chamber in the rear? is that a suspension upgrade or adjustment?
Old Apr 9, 2006 | 01:17 AM
Jason@Performance
Performance Nissan
stock camber is already very negitive...
will have to purchase some camber / toe arms...
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
