Question re: spark plug anti-seize
Old Mar 22, 2006 | 07:32 AM
gersteinp's Avatar
gersteinp
Default Question re: spark plug anti-seize
Did a spark plug change last week using some aluminum-containing anti-seize on the threads. Today I read the only copper anti-seize should be used. Some even recommend no anti-seize because it leads to over-torquing.
My question is whether it's worth the hassle of taking out the plugs to clean off the aluminum anti-seize and replace with copper stuff or nothing at all. Has anyone used the aluminum stuff and had no problems with the plugs fusing to the aluminum head a year later? I hate to go through the process all over again.
Old Mar 22, 2006 | 02:21 PM
first350's Avatar
first350
you might want to...Al melts at a lower temp than Copper.
Old Mar 22, 2006 | 02:51 PM
SpeedRcr's Avatar
SpeedRcr
i used the aluminum when i put in my denso iridiums...never had a problem in the past on other cars
Old Mar 22, 2006 | 08:06 PM
gersteinp's Avatar
gersteinp
Did the past cars have aluminum heads? That appears to be the problem because similar metals can fuse after prolonged contact.
Old Mar 23, 2006 | 07:42 AM
97supratt's Avatar
97supratt
You'll be fine, as long as you put some sort of anti-seize then your okay. The only purpose of anti-seize is for aluminum heads so your good, no worries.
Old Mar 23, 2006 | 07:43 AM
King Tut's Avatar
King Tut
My past 3 cars have all had aluminum heads and I have always used the standard silver anti-seize and have never had fusing issues.
Old Mar 23, 2006 | 05:35 PM
gersteinp's Avatar
gersteinp
Thanks! I feel better now.
350z82
Oct 1, 2015 06:25 PM
