engine has been pulled... what upgrades would be best while it's out..headers/clutch/
on
my engine is out of my car and while its out chilling in the wind i thougth i'd add some stuff to it.
engine is an non-rev up
what would some good headers be (gains/fitament/price)
should i put some nismo cams in
clutch and fly wheel.......rev up lower plenum?
basicly its already apart and it cost the same to put the stock stuff back on. cams are not out but one head has been pulled off the motor.
any ideas on what mods would be most costefective to do now, with the motor already pulled?
on
since heads are off the engine, you can be able to replace a stronger set of rods in.... cams will be good too since the heads are off!
You can basically build up the entire engine now though to be honest! but I will definitely do these if money allows...
- Conrods
- Pistons
- Cams
- Headers
cheers,
richie
- Conrods
- Pistons
- Cams
- Headers
cheers,
richie
I would suggest JWT cams, crawford headers, crank pulley and my REVUP lower plenum, good luck.
on
ya im not going to do the forged ingine rebulitd just cams and header for now. and maybe a little somthing else?
basiclay now there fixing it under warrenty but i want to switch out cams and valves to after market
Forged Performance
Forged Performance
If you are committed to staying NA, I would do headers, clutch/flywheel upgrade, and pulley's while the engine is out. JWT cams if your budget permits. Everything else could be installed after the engine is reinstalled.
But while you're at it, its the perfect time for a forged engine swap, and TT kit.
liqalu04
01-02-2022 12:58 PM
