My AFRs on bank 1 versus 2 are way off
Old Apr 23, 2006 | 11:41 AM
Kiamo's Avatar
Kiamo
Default My AFRs on bank 1 versus 2 are way off
I installed a UTEC and was working with it, but I kept noticing over 6K the car feels like it loses a good bit of power. I did an AFR log with Cipher and noticed the banks over 6K do not match. Any suggestions on what to do about this?
edit: I did some more log runs, tried resetting the ECU and disabling the UTEC and it still does it, but with the UTEC off the banks are reversed (wtf?).
This really sucks. I have **** for power over 5700 RPM. My midrange is very strong, then I hit just past 5700 and the power takes a big crap, and the higher it revs the worse it gets.
Does anyone have any ideas?
Old Apr 23, 2006 | 01:40 PM
InZomniac's Avatar
InZomniac
Bad injector?
Old Apr 23, 2006 | 03:05 PM
Kiamo's Avatar
Kiamo
Originally Posted by InZomniac
Bad injector?
I hope not... its a 2005 with 9200 miles on it.
Old Apr 23, 2006 | 11:47 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Here's my 2 cents from a scientist's standpoint:
did you only do 1 experiment? You cannot prove that the AFRs are statistically significantly different unless you have done several experiments.
Old Apr 24, 2006 | 05:01 AM
dovla's Avatar
dovla
You might like to see this thread on g35driver forum about AFR B1 vs B2 discrepancy.
On my car, AFR on B2 is almost always higher. I even swapped sensors to eliminate calibration issue.
I read UTEC manual but I don’t remember seeing if it can control injectors separately?
Old Apr 24, 2006 | 06:13 AM
Kiamo's Avatar
Kiamo
Ok, that's good to know then. Any idea why I lose so much power over 5700 RPM? I've tried no UTEC (map 0), using "ECU" in timing/fuel maps over 5750 in the UTEC, and my own tune, and they all do it.
I have all the UTECs settings about what the default parameters are, short of the revlimit, which is set to 70 (instead of 72 or whatever it was at).
Old Apr 24, 2006 | 06:46 AM
dovla's Avatar
dovla
Disclamer: I have no clue …
Kiamo, log your timing and cams and injectors pulse and see what you have above 5700 RPM.
Does UTEC shows any knocking? Do you have any intake mods? What year is your car?
Old Apr 24, 2006 | 07:14 AM
Kiamo's Avatar
Kiamo
Timing is fine, and my UTEC settings are actually ever so slightly less agressive over 5700 RPM. Injector pulse looks normal, raising slighly over the RPM range.
UTEC is showing no knocking, timing isn't being pulled (which is almost what it feels like, though). I have JWT intake, Crawford upper plenum, headers, test pipes. The car is a 2005 Enthusiast.
edit: injector pulses are virtually identical on both banks through the rev range. At 2500 RPM, its around 12.2, rising to 15.8 by 6500 RPM, pretty linearly.
May 30, 2017 03:28 PM
bcoffee20
Nov 19, 2015 06:39 PM
Mattg350z
Oct 2, 2015 06:51 AM
Bigsyke
Sep 11, 2015 06:19 PM
