Problem with CNR Pulley???
Old Aug 18, 2006 | 07:45 PM
  #61
islandsnow's Avatar
islandsnow
thanks for the pics, i'm putting the UR on as soon as i get it.
Old Aug 20, 2006 | 06:14 AM
  #62
MustGoFastR's Avatar
MustGoFastR
Originally Posted by Jeff92se
I just did a quick search. I don't know how up to date these pics I found are:
Black UR pulley. Looks like it's machined or sleeved:
https://my350z.com/forum/attachment....5&d=1143568009
Red set:
I'd say those pics are inconclusive; need close-up shots. Besides, if I'm not mistaken, it's the INSIDE of the hole, where the alignment channel is that's taking damage, right? Wish Havok would get the pics up of his damaged pulley...
Old Aug 20, 2006 | 09:22 AM
  #63
islandsnow's Avatar
islandsnow
If you look at the black pulley picture, it looks like a solid piece of steel in the center. Isn't that the inside portion of the pulley, the part that sticks out? So what i gather from all this is that once the crank gear area wears out and starts to wobble, it starts rubbing into the crank seal and will cause it to fail. Well, i ordered my pulley through e-bay, so it's taking forever. Once i get it, i'll post closeup pics.
Old Aug 21, 2006 | 03:40 PM
  #64
Jeff92se's Avatar
Jeff92se
Actually the black one looks like it has a steel sleeve while the red one does not. Confusing.
No. The inside of the hole is where the pulley slides onto the crank w/ the alignment key. It's the outer portion that the seal rides on.
Old Aug 23, 2006 | 08:25 AM
  #65
MustGoFastR
Nobody got detailed pics yet, huh?
Old Aug 23, 2006 | 08:35 AM
  #66
islandsnow's Avatar
islandsnow
sorry, ebay guy said there was a glitch in the computer (yeah right) and had to re-order it.
Old Aug 23, 2006 | 08:55 AM
  #67
JonathanAboona's Avatar
JonathanAboona
still working on getting the finite pics and brief description posted. I am trying to get my motor done and have been real busy with that.
Jon
Old Sep 6, 2006 | 07:05 PM
  #68
islandsnow's Avatar
islandsnow
Default pics of UR pulley
okay, this pulley was an ebay special UR pulley, it looks legit though. The center outside part does look like it's sleeved, but then when you look at the other side you don't see anywhere it's attached. The key groove looks like the normal aluminum, it's the outer portion that looks like it has a sleeve, because of the line. You will see in the pics what i'm talking about.
front shot, you don't see anything different from a kjr/cnr
http://www.mindspring.com/~islandsno...%20(Large).JPG
side shot, you can almost see the line
another side shot
this one you can see the line, but i'm not 100% positive it's a sleeve.
Old Sep 7, 2006 | 03:35 AM
  #69
DavesZ#3's Avatar
DavesZ#3
Actually, from the last picture it looks like the end is chamfered a little bit. The slight angle makes the light reflect off it differently and that's why it looks different from the side shots.
Old Sep 7, 2006 | 04:30 AM
  #70
islandsnow's Avatar
islandsnow
okay, i was looking at the pulley a little closer. The part that is beveled is the sleeve everyone is talking about, that's why it does look like brushed stainless. I thought maybe the key area was reinforced somehow, but it's not, it's pretty much all aluminum except for maybe this 1 mm thick sleeve i guess where the crank seal sits. Not really sure how this makes this pulley stronger then the others though.
Old Sep 7, 2006 | 05:29 AM
  #71
teh215's Avatar
teh215
It doesn't make the pulley structurally stronger but, it does make for a harder wear surface so that the rubber oil seal does not wear a groove in the softer aluminum. The groove seems to be where everone is having the leaking issue.
Old Sep 7, 2006 | 12:56 PM
  #72
MustGoFastR
Confirm the presence of the sleeve with a magnet. The pulley is AL, so if the sleeve is steel...
Is it a cap or a capped insert that goes down through the key hole?
I wonder how it is mated to the AL pulley?
Old Sep 7, 2006 | 07:43 PM
  #73
islandsnow's Avatar
islandsnow
it's a steel sleeve, confirmed via magnet. It's exactly what teh215 said, it's there to prevent wear from the bearing riding on it. Here is a couple of more pictures with where the sleeve is marked.
http://www.mindspring.com/~islandsnow/pulley1.jpg
http://www.mindspring.com/~islandsnow/pulley2.jpg
Old Sep 8, 2006 | 07:50 AM
  #74
MustGoFastR
Gotcha. Thanks for the detailed pics. Well, if my CNR starts to show signs of going, I'll just have to replace the seal and pick up a UR pulley to replace it. It's doing just fine, presently, though.
Havok, you ever gonna get pics of your damaged pulley up?
Old Sep 8, 2006 | 06:42 PM
  #75
islandsnow's Avatar
islandsnow
No problem, just read the install instructions on the UR, it says the 1mm sleeve is pressed on, so that the crank seal rides on sleeve and seals the crankcase. Anyways, my CNR is not showing any adverse signs either except for the squeeking. Might try to install the UR this weekend and see if i can feel the difference.
Old Sep 11, 2006 | 03:13 PM
  #76
islandsnow's Avatar
islandsnow
here's a pic of my cnr after only a few hundred miles. don't know if this is the problem everyone's talking about? definite wear on the outside, see the rings grooved into outside, the key was fine, since they did torque mine correctly on install.
http://www.mindspring.com/~islandsnow/pulley3.JPG
Old Sep 11, 2006 | 07:48 PM
  #77
reptile718's Avatar
reptile718
so was your squeal caused by the belts or the crank pulley, I don't see how the pulley would cause the noise? please explain. thanks for the pic, ill deff be in the market for a new ur crank pulley next week, how much did it cost you and is it stock size like cnr?
Old Sep 11, 2006 | 08:20 PM
  #78
islandsnow's Avatar
islandsnow
Rep,
the squeal was because my belts were loose. No squeal yet with the new gates belts and the UR pulley. The gates belts are shorter as the UR pulley is an underdrive pulley. Below are the prices and numbers for the belts you need, these are gates belts. I bought them from www.rockauto.com. The pulley was 148.00 from ebay, the vendor was city-speed, but the weird thing is i think they order the pulley when the next one is purchased, so it took me almost a month to get it.
GATES K060445 Accessory Drive Belt $ 13.85 $ 0.00 1 $ 13.85
GATES K040353 Accessory Drive Belt $ 7.66 $ 0.00 1 $ 7.66
Shipping $ 7.01
Order Total $ 28.52
Old Sep 12, 2006 | 06:52 AM
  #79
Havok_RLS2's Avatar
Havok_RLS2
^^^^^ EXACTLY!!!!
Thanks you so much for posting this photo. This is exactly what I've been talking about.
Old Sep 12, 2006 | 07:05 AM
  #80
John@Victory's Avatar
John@Victory
i dont know why you guys are so on to the ur pulley is better kick... there are over a dozen of us that have lost motors because of the ur pulley too....
