Engine Hesitation
Old May 24, 2006 | 05:29 AM
wren57's Avatar
wren57
Default Engine Hesitation
For some reason whenever I drive hard and hit the 1-2 shift at around 6800rpm my Z hesitates for a brief 1/4-1/2 second as soon as I shift into 2nd. VDC is off, of course, and the tires bark... as soon as the tires grab the engine hesitates. I have the UTEC on base map 1, but I recieve 0 knock count all the way up to 7200rpm, even with knock sensitivity at high level. What could this possibly be?
Old May 24, 2006 | 01:10 PM
ACEMAN's Avatar
ACEMAN
Master
Looking at your logs, what is your A/F around that time?
Later
Aceman
Old May 24, 2006 | 09:05 PM
0260n4's Avatar
0260n4
Angry 2500 RPM dilemma
My problems are even worse, after beating on my Z on the track and of course I’m will into the rev limiter, I’ll shut down far a short period to tweak suspension. Then after restarting the car it doesn’t exceed 2500 rpm even in neutral. Not even a check engine light comes on and after an excruciating long rest every thing works. If any one comes up with any ideas this or to the original thread please give me some info.
Old May 25, 2006 | 11:14 AM
ACEMAN's Avatar
ACEMAN
Master
Make sure the connection to your MAF sensor is tight and do a ECU reset.
Had this happen to me.
Later
Aceman
Old May 25, 2006 | 11:40 AM
wren57's Avatar
wren57
Not sure what my AFR is at that time because I've yet to install a wideband. That shall all be fixed this weekend when I get and install my Innovate LM-1. However, I don't think it could be an AFR issue because I still get zero knock and the engine doesn't hesitate in that (or any) RPM range except immediately after the tires grab on the 1-2 shift under WOT. I'll get back with some info this weekend.
Old May 25, 2006 | 11:58 AM
0260n4's Avatar
0260n4
Thanks aceman i'll let you know the results
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
