Clutch slave gone bad?????
Old May 28, 2006 | 04:40 PM
D350Z10's Avatar
D350Z10
Default Clutch slave gone bad?????
Whats up guys, I did a search and found nothing on this issue.
My clutch slave cyclinder seems to have gone bad the clutch pedal wont release out sometimes and I have to pump it to get her back out. Its only been 10k on the entire car. Do they out quite offten?
Issues... Nissan Dealership, under warranty?
Old May 28, 2006 | 06:40 PM
hide187's Avatar
hide187
Master or slave cylinder. Check your floor, or the place where your clutch pedal goes through the firewall for leaking (brake) fluid. Thats what happened to my eclipse gst, after 50k miles, not ten.
Old May 29, 2006 | 07:26 AM
peptidbond's Avatar
peptidbond
Whats up!
Sorry to hear about your issues. You are F/I right? And I think you are S/C with headers too, right? If yes, then I know what your problem is.
Does the problem happen all the time, your just after you have been driving really hard? When it happens, does the symptom only last fow a brief period and then everything is normal again? If it only happens after a hard drive and the symptom goes away quickly, then I would guess your are boiling the hydraulic clutch fluid. With aftermarket headers, especially on an F/I car, it is really easy to boil the clutch fluid.
This happened to me at Tail of the Dragon. I have the Crawford headers (N/A) and I talked to Doug about it. He said this is really common. All the guys in the shop simply switched to Mutol 600 for the clutch fluid and no longer have a problem.
I just made the switch this weekend (to Ate Typ 200). If this sounds familiar, take the cheap and easy step of switching the hydraulic fluid first and see what happens. If this does not match your symptoms, sorry I cannot help.
Old May 29, 2006 | 07:37 AM
D350Z10's Avatar
D350Z10
THANKS!!!!!! I am gonna switch the fluid now, thanks alot guys!
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
