6th to 5th Grind
Old Jun 9, 2006 | 03:57 AM
njsho's Avatar
njsho
Default 6th to 5th Grind
Ive searched and I see alot of people have a problem with a 4 to 5 shift grind. Ive been having problems with 6 to 5 grind. If I pause for a second between gears its fine. If I shift normally I get a grind, it goes in, but it does grind. Is this normal or should I take it to the dealer to look at?
Old Jun 9, 2006 | 04:17 AM
Clyde's Avatar
Clyde
Default Grind
Unless you are not properly engaging the clutch before shifting, any grind is a problem that should be looked into.
Old Jun 9, 2006 | 04:30 AM
If you take the car to the dealer, at the end of the day they will call you and say Cannot duplicate.
Old Jun 9, 2006 | 09:19 AM
Apex2986's Avatar
Apex2986
are you rev matching when you downshift?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Vigman
Nov 17, 2015 04:34 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
duncan
Nov 2, 2002 04:31 PM
rai
Jul 22, 2002 03:16 AM
