aluminum drive shaft
Old Jun 24, 2006 | 12:00 PM
spracked's Avatar
spracked
Default aluminum drive shaft
my local shop recomends this modification, apparently it weighs 7 pounds less than the stock drive shaft. any opinions if its worth the 500 dollar price tag?
thanks
Old Jun 24, 2006 | 12:20 PM
rythex's Avatar
rythex
First time I've heard of anyone replacing the stock carbon fiber one. :P
Old Jun 24, 2006 | 12:31 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
ummm....
4lbs drive shaft! cool!
Dont think they know how light weight the stock Z33 one is to begin with...
Old Jun 24, 2006 | 12:36 PM
spracked's Avatar
spracked
i thought the z33 driveshaft was closer to 14lbs. i had no idea it was that light.
Old Jun 24, 2006 | 01:29 PM
Jason@Performance
Performance Nissan
it may very well be 14lbs... but its really light... lighter then what I would think the OE one would be if aluminum...
we have schredded a few drive shafts... there isnt much to them....
Old Jun 24, 2006 | 01:45 PM
undrgnd's Avatar
undrgnd
Since it doesn'ts appear like anyone knows for sure, how about someone weigh the OEM one and then 'spracked' can get the one that his local shop recommends weighed, and we'll all know. Would this be considered the type of weight similar to unsprung weight off of an axle, or like a crank pulley, or something in between?
Old Jun 24, 2006 | 02:01 PM
sentry65's Avatar
sentry65
the burninator
i don't think an aluminum driveshaft will be as strong as the stock carbon fiber with steer reinforcement driveshaft
Old Jun 24, 2006 | 02:10 PM
Jason@Performance
Performance Nissan
I dont have a stock one instock :-/
No cars in the back getting a tranny done...
Next time I see one, ill snag the shaft and weigh it....
Old Jun 24, 2006 | 09:42 PM
rythex's Avatar
rythex
And the original poster should get the weight of the aluminum one.. :P
Old Jun 24, 2006 | 09:50 PM
spracked's Avatar
spracked
the stock one is stronger however I plan to stay NA so its kind of irrelevant. just trying to shave as much weight off as possible
Old Jun 24, 2006 | 09:51 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
why replace the strong one with a weak one to save 7 lbs. You can save 7 lbs by taking off your shoes and jewelry before getting in the car.
Old Jun 24, 2006 | 10:21 PM
plumpzz's Avatar
plumpzz
on top of that, since its a driveshaft it doesnt have much radius so the unsprung weight isnt that unsprung.
you'd get more of a difference by shedding 10 lbs off the outside of a flywheel than 30 lbs off the inside of a flywheel for example. Since the driveshaft is only a few inches wide in the first place, loosing 7 lbs wouldnt do much.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
