NEW! Project Kics Drain Bolts!
Old Jul 7, 2006 | 01:40 PM
Brian@Performance's Avatar
Brian@Performance
Performance Nissan
Default NEW! Project Kics Drain Bolts!
Mackin just announced today that Kics just released these new drain bolts for all types of applications! This direct replacement for your stock plug is made of aluminum with a magnetic tip at the end. Comes in gold for Nissans!
Readily available on our site today!! http://www.mynismo.com/products/?id=4767
Old Jul 7, 2006 | 02:11 PM
amG35's Avatar
amG35
Brian, pardon my ignorance, but what is the purpose of the magnetic tip? Also may I assume this will fit the G35? Thanks.
Old Jul 7, 2006 | 02:21 PM
MyNismoRoadster's Avatar
MyNismoRoadster
I believe what its supposed to do is collect ferrous metal particles from various parts of the engine floating in the oil. The VQ is aluminum block but various parts like the cylinder sleeves, cams, lifters, crank, rings, con rod, etc is all made of metal that can be attacted to the magnet on the drain plug.
Old Jul 8, 2006 | 07:00 AM
BigZ88's Avatar
BigZ88
to anyone that uses these, please remember to use a torque wrench and torque to proper settings, otherwise bye bye oil pan.
Old Jul 8, 2006 | 08:41 AM
n8vz's Avatar
n8vz
I presume it can be used with OEM copper washers?
Old Jul 8, 2006 | 09:49 AM
Quamen's Avatar
Quamen
Hmmmm. I may be purchasing a bunch of these from you in the next month.
Old Jul 8, 2006 | 08:50 PM
Volk350Z's Avatar
Volk350Z
Master
can't wait to get them on my car...
Old Jul 9, 2006 | 11:57 AM
MyNismoRoadster
Yes, that is correct, it is designed to accept the standard Nissan crush washers.
Old Jul 9, 2006 | 12:00 PM
MyNismoRoadster
Well its more like bye bye to the Kic's plug bolt, the factory oil pan is steel and its stronger then the aluminum thread. But yes torque setting is pretty crucial as aluminum is softer and cannot be crammed on hard like the oem Nissan steel bolts, i would probably tightened these no more then you would tightened spark plugs.
Old Jul 9, 2006 | 01:16 PM
BigZ88's Avatar
BigZ88
yes, but if you over torque it and booger up the threads, that bad boy is not going to come out. Also, the crush washers are aluminum are they not?
Old Jul 9, 2006 | 03:23 PM
MyNismoRoadster
The Crush washers are made of copper, as for the pan, the aluminum will strip first, if the pan threads get deposited with the stripped aluminum you can clean them out with a tap.
Old Jul 18, 2006 | 08:59 AM
Brian@Performance
Performance Nissan
Bump for a nice product! The plugs we have in stock are actually the red ones!
Old Jul 18, 2006 | 11:29 AM
21112's Avatar
21112
Does this just replace the oil pan drain plug?
Will it replace the tranny and rear differential drain plugs as well?
Old Jul 19, 2006 | 07:10 AM
Brian@Performance
Performance Nissan
Unfortuantely, the tranny and differential plugs are quite a bit larger than the engine drain bolt.
And yep! It replaces the oil drain plug.
Old Jul 19, 2006 | 12:15 PM
21112's Avatar
21112
Well 1 for 3 ain't bad.
Next time I order from you, I'll have to pick one up.
You should get on the horn to them and tell them to make a magnetic tranny and diff plug as well.
Old Jul 19, 2006 | 02:20 PM
failsafe306's Avatar
failsafe306
Do these void the factory warranty?
Just kidding! I may be ordering one very soon.
Old Jul 19, 2006 | 05:13 PM
Volk350Z's Avatar
Volk350Z
Master
the Stock Diff plug is magnetic.. so only need the Tranny...
Old Jul 19, 2006 | 06:15 PM
MyNismoRoadster
I dont know about the 350Z trans plug but the Z32 OEM one is magnetic, maybe you can use the Z32 ones?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
burglapfd
Dec 6, 2020 01:04 PM
