High oil useage with synthetics
There are many threads about the high oil useage of our Z's, some using a quart in as little as 800 miles. Many of them are using Mobil 1 and other synthetics. When I first got my 2003 Z, it had 54000 miles on it and about 400 on a Mobil 1 10W30 oil change. In another few hundred miles, it was down a quart.
Having always used high quality 20W50 in my 5 other Z's, I put in a quart of that weight, non-synthetic. In about 1000 miles, I was down another quart.
Put in another quart of 20W50. Now have another 1000 miles and guess what. Not a drop down.
40% of what is in there now is non-synthetic 20W50. Could the high oil useage on mine and others have something to do with using synthetics or perhaps the lightness of the 10W30?
BTW, there were major problems with Mobil 1 in aircraft engines several years ago and it was pulled out of that market.
Originally Posted by 97supratt
Synthetic oils do burn more than regular oils.
I am testing out redline oils on my car, because I would burn a lot with royal purple.
bill
Originally Posted by Ztalker
synthetic oil is a complete waste of money imo...i switched back to dyno oil in my Z last year.
I've used strictly Mobil 1 in my last two vehicles. Never any probs. or oil consumption.
The only way that I could see oil consumption is through old leaky gaskets. Synthetic oil molecules are homogeneous and conventional oil molecules vary in size so that if a microscopic leak forms the larger molecules from the conventional oil could possibly clog or block the leak before it starts. While the smaller uniform molecules of synthetic oils don't have ununiform larger molecules in the mix to do this. Either way the oil isn't the problem, gaskets need to be changed from time to time.
Originally Posted by diwun67
Run two engines for 100,000 miles, one with synthetic, one with regular dyno oil, then tear them apart. You'll change your tune.
Originally Posted by bailey bill
That's a myth.
Uhh...Redline is a synthetic.
bill
bill
I know redline is synthetic, so is royal purple buddy. I was trying to say I was burning more oil running royal purple than I am running redline.
bill
Originally Posted by zzz350
Other members report less burning with Royal Purple, explain that.
How much are you burning with the Redline? I am burning some Royal Purple. I have some Amsoil on the shelf i'm going to try next.
