Burn out question?
Old Jul 13, 2006 | 02:51 PM
eltness350's Avatar
eltness350
The Untouchable
Default Burn out question?
I heard there is a fuse that you can pull to allow a burn out. Is this true? I have a procharger and it seems like I cant get a good burnout at the track..And yes I have the traction control off..lol
Old Jul 13, 2006 | 03:14 PM
Fairlady_z33's Avatar
Fairlady_z33
yes its in the fuse box next to the rest pedal
Old Jul 13, 2006 | 03:30 PM
eltness350's Avatar
eltness350
The Untouchable
What fuse would it be? and what does it do??
Old Jul 13, 2006 | 04:56 PM
TruBluZ's Avatar
TruBluZ
brake light fuse
Old Jul 13, 2006 | 07:00 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
its the brake light fuse, if you pull the right one your brake lights wont work, this bypasses nissans stupid burnout problem. make sure you put it back in though when you drive...
Old Jul 14, 2006 | 01:08 AM
eltness350's Avatar
eltness350
The Untouchable
thanks guys
Old Jul 14, 2006 | 06:01 AM
pingrr's Avatar
pingrr
Will pulling this fuse alow you to power brake the car? I have never had a problem doing long burnout I just can't powerbrake the car.
Old Jul 14, 2006 | 06:07 AM
Eazzy's Avatar
Eazzy
This is interesting --Would someone explain in technical terms as to just what pulling the fuse does ????
HarvesterUT's Avatar
HarvesterUT
normally, when braking...i think the engine cuts power
Old Feb 8, 2007 | 10:40 AM
zero0 2 sixty's Avatar
zero0 2 sixty
Wow Im Definatly Tryin This!
Old Feb 8, 2007 | 03:38 PM
gbart's Avatar
gbart
is there anyway to just override this permanitly with the lights still working anytime i wanna do a burnout or somethin i wouldnt wanna get in the fuse box and pull it.
Old Feb 8, 2007 | 03:43 PM
redman333's Avatar
redman333
Someone is already tryin to figure out how to do this. Check this thread out. There is no easy way to do it.
https://my350z.com/forum/forced-induction/231581-brake-boosting-a-tt-350z.html
Old Feb 8, 2007 | 04:07 PM
TruBluZ's Avatar
TruBluZ
There was a guy on here that made a switch that you plug into the fuse block. When you want to do a burnout, just flip the switch. When you are done, flip it back.
Old Feb 14, 2007 | 06:24 PM
nathanwl2004's Avatar
nathanwl2004
Default base model
wow I have a base model which thank god doesn't have traction control, I've never had any problems doing a burn out what so ever.
base has it's advantages
Old Feb 14, 2007 | 06:29 PM
Brick-Z's Avatar
Brick-Z
Prediction:
"Damn man, I pulled my brake light fuse and hit this guardrail."
Old Feb 14, 2007 | 06:36 PM
UGOTZ'D's Avatar
UGOTZ'D
Originally Posted by Brick-Z
Prediction:
i second that prediction!
Old Feb 15, 2007 | 03:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I bet that one wheel wonder of a burnout really impressed everybody
Old Feb 15, 2007 | 05:17 AM
done12many2's Avatar
done12many2
Don't take much to snap one loose.
Old Feb 15, 2007 | 05:48 AM
MustGoFastR's Avatar
MustGoFastR
Wow, can't believe no-one has throw out the "USE THE SEARCH FUNCTION" on this topic that's been beat to death...
Old Feb 15, 2007 | 05:59 AM
03ZHIFT's Avatar
03ZHIFT
Traction control scares me. You don't have full control of what exactly the wheels do. The last thing I want is the car to apply the brakes/cut throttle depending on the TC system.
