KNOCK question!!!
Old Aug 7, 2006 | 08:23 AM
tecni's Avatar
tecni
Default KNOCK question!!!
If your knock sensor is bad. What effect would it have on the car's function?
Would it make it turn but not throw spark?
Old Aug 7, 2006 | 12:57 PM
Wheelman's Avatar
Wheelman
Knock sensor usually pulls timing when it detects knock. I'm unclear exactly what you are proposing, but if shouldn't have any affect on the car starting if thats what you're getting at.
Old Aug 7, 2006 | 02:09 PM
superchargedg's Avatar
superchargedg
Damn Noobs
+1
Old Aug 7, 2006 | 02:43 PM
tecni's Avatar
tecni
dang it LOL
Old Aug 18, 2006 | 09:25 PM
tecni's Avatar
tecni
Problem Solved!!! Car wouldn't start because of bad timing. Got it timed and runs well.
Funny thing is... the car now only rins with the crank sensor unplugged!?
Old Aug 19, 2006 | 04:34 AM
booger's Avatar
booger
Then it sounds like it was and is bad . Go buy another one and plug it in and see if it runs with it plugged in.
Old Aug 19, 2006 | 06:44 AM
tecni's Avatar
tecni
I have 2 and one of em is brand new. Its something else.
Old Aug 20, 2006 | 07:32 PM
ouch1011's Avatar
ouch1011
Check for damage to the reluctor wheel that the CKPS reads. Also check the wires and the pins in the connector for the sensor.
And a bad knock sensor will retard the ignition timing ALOT, make the car really sluggish in the lower RPM band, and turn on the check engine light.
Old Aug 20, 2006 | 09:06 PM
tecni's Avatar
tecni
Default Ckps
when you say check the wheel. YOu mean the rim of the flywheel that the CKPS reads?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
