The New VQ Motor...EXCLUSIVE...
Old Aug 29, 2006 | 06:11 PM
mraturbo's Avatar
mraturbo
Sweet Info Jeremy.
M
Old Aug 29, 2006 | 06:12 PM
05-Z's Avatar
05-Z
What's the HR stand for? It can't be human resources.
edit...jeremy beat me to it.
Old Aug 29, 2006 | 06:15 PM
350Zenophile's Avatar
350Zenophile
2007 Infiniti G35 Sport Coupe
The Infiniti G35 coupe remains a standard-bearer in the sports coupe class since its introduction in 2003. For 2007, the standard VQ 3.5-liter DOHC 24-valve V6 engine produces 275 horsepower and 268 lb-ft of torque, while the G35 Coupe 6MT model generates 293 horsepower and 258 lb-ft of torque.
The refined performance coupe also features standard High Intensity Discharge (HID) bi-xenon headlights, available Infiniti Navigation system, as well as other luxury and performance options. Also available are a Rear Active Steer package, which includes vehicle-speed-sensitive power steering and 15.1:1 steering gear ratio, and an available Sport-Tuned Suspension Package with 19-inch forged aluminum wheels and Viscous Limited-Slip Differential (VLSD). Standard on the G35 Coupe 6MT are the Viscous Limited Slip Differential and unique front fascia and side sills.
Enhancements to the 2007 G35 Coupe include:
· Standard Intelligent Key (not available on G35 Coupe 6MT)
· Standard auto on/off headlights
Why does the sedan get the 4th gen VQ and not the Coupe?
Old Aug 29, 2006 | 06:22 PM
DIGItonium's Avatar
DIGItonium
Much of the info has been posted in the G35 section. There's a link to the VQ sound. It's throaty, and it seems to lack the exhaust drone of the Z, FX, etc. - which is a plus for me. C&D previewed the 6MT Sport version, and it is just as fast as an IS350. Too bad it is a pig which is why I'm hesitant about the new coupe. I'm worried about the loss of handling performance vs. the Z in stock form.
Old Aug 29, 2006 | 06:28 PM
Fairlady_z33's Avatar
Fairlady_z33
The big question is if it can be put into r old cars and will it work right. What do you guys think i like my vq but it qould be nice to have some newer things on it. I guess this will hold some people back from building the old VQ's
Old Aug 29, 2006 | 06:30 PM
zz350zz's Avatar
zz350zz
**** let me get another pop-charger
Old Aug 29, 2006 | 06:37 PM
350Zenophile
I doubt this would be an easy or worthwhile swap (intake). The boys at Crawford tried building a dual intake plenum/setup and abandoned the project.
Old Aug 29, 2006 | 06:44 PM
EM-EFER's Avatar
EM-EFER
At least daul turbonators will be possible now
Old Aug 29, 2006 | 07:17 PM
Weqster's Avatar
Weqster
dual intake is just bling. u will need to reconfigure the ECU to accept 2 tps, 2 maf signals etc, or like this japs have done already, manipulate the signals to suit. any of the aftermarket units out there will perform as good as this IMO. Exhausts, well aftermarket exhaust = fix.
The intertesting stuff is the CVCT which will give great gains once there is an EMS out there capable of altering it? Motec? This technology is already found on honda's i-vtec and gives great response/gains when tuned for ur setup.
Old Aug 29, 2006 | 08:57 PM
AmyCroft's Avatar
AmyCroft
Smile Humm Fast Light off Sensor
Is that not the problem that JWT had with getting the JWT 350Z Kit CARB Certified?
fast light-off O2 sensor control
We may see a Carb Certified JWT kit for the "old Cars" soon..
Cheers Amy -
Old Aug 29, 2006 | 09:00 PM
zz350zz's Avatar
zz350zz
So assuming you buy this whole motor.....you would be able swap it in since the Z's body style won't change?
Old Aug 29, 2006 | 09:05 PM
AmyCroft's Avatar
AmyCroft
Smile Thanks Audible Mayhem - A new VQ
Originally Posted by Audible Mayhem
* HR stands for High Response (or High Revolution)
* 5th Generation of the VQ.
* Redline increase to 7500rpm
* Redesigned block for increased rigidity
* Complete symmetrical intake and exhaust systems
* Worldwide first hydrogen free DLC (Diamond Like Carbon) [hu] due to coding adoption decrease
* Setting electromagnetism VTC on exhaust cam side in addition to the oil pressure VTC of air inlet cam side,
* Adoption of isometric exhaust manifold
* Higher compression ratio: 10.6:1 (previously 10.3:1)
They have a 2007 Infiniti G35 Sedan
more...
NISSAN DEVELOPS NEW-GENERATION V6 ENGINES --Engines to power all-new Skyline to be released this autumn--
TOKYO (Aug. 22, 2006)--Nissan Motor Co., Ltd., has newly developed two new-generation six-cylinder V-type engines for front-engine, rear-wheel-drive vehicles featuring powerful performance and improved environmental friendliness.
The 3.5L VQ35HR and 2.5L VQ25HR engines will be built at Nissan's Iwaki Plant in Fukushima Prefecture and will be equipped in the all-new Skyline to be released this autumn in Japan, as well as the US where the model is sold as the Infiniti G35.
Featuring newly designed engine blocks and other key components, the engines offer smooth transition to top-in-class level engine speed of 7,500 revolutions per minute drawing upon the "smooth transition" concept of the popular VQ engine, the only engine in the world to appear on Ward's 10-Best Engines list for 12 consecutive years.
The engines achieve a 10% improvement in fuel efficiency compared to vehicles equipped with the existing VQ engine and top-in-class Super Ultra-Low Emission Vehicle level emissions. SU-LEVs have 75% or less nitrogen oxide (NOx) and hydrocarbon (HC) emissions than those stipulated by Japan's 2005 exhaust emission standards.
The letters "HR" in VQ35HR and VQ25HR stand for "high revolution" and "high response."
Nissan began VQ engine production in 1994 and has produced a cumulative total of 5.5 million units as of last fiscal year, ended March 31, 2006.
Main specifications of the VQ35HR and VQ25HR engines:
Smooth transition to top-in-class level engine speed of 7,500 rpm
* Reduction of weight and friction through adoption of asymetrical piston skirt configuration
* Reduction of piston-side force through lengthening of con rod
* Addition of rudder frame, newly-designed cylinder block with significantly improved rigidity
Thrilling revving sound and top-in-class output
* Adoption of perfectly symmetrical intake system
* Adoption of continuously variable valve timing control (CVTC) for intake side and electromagnetic valve timing control (e-VTC) for exhaust side
* Reduction of intake resistance through adoption of symmetrical twin intake system and straight intake port
* Adoption of isometric exhaust manifold and perfectly symmetrical exhaust system
Improvement of fuel-efficiency and emission cleanliness
* Reduction of friction through adoption of world's first hydrogen-free, diamond-like carbon (DLC) coating
* Adoption of catalyst substrate with ultra-low heat mass, super-ignition iridium spark plug and fast light-off O2 sensor control
Thanks for the head up.. Send us all updated specifications
Cheers Amy -
Let's see it the Fast Light up sensors can cure the JWT TT Kit issue.. For Carb Certification.
Old Aug 29, 2006 | 09:16 PM
o snap its eric's Avatar
o snap its eric
i for one is really excited about the dual intake, i want too see this being put on to our current engine and making power!
Old Aug 29, 2006 | 09:47 PM
Fairlady_z33
with a standalone i see no problems
Old Aug 29, 2006 | 10:43 PM
g35_anonymous's Avatar
g35_anonymous
Nissan straight up gave them the car after it had crashed during testing. That's the word on the street at least. That's some partnership eh?
Old Aug 30, 2006 | 07:58 AM
Resolute's Avatar
Resolute
Looks like bolt-ons are going to give even less gains to me. The engine is really nice, but it already comes with true dual exhaust, equal length exhaust manifolds, split intake with straighter runners... Exhaust and header mods probably won't give as much as the little amount they do now. CAI or pop chargers won't be as effective I think either. The heads could use some porting to edge the intake splitter, but it looks like this engine, even more than the current gen VQ, will need some serious internal work like cams and ECU tuning to make decent N/A power.
I like the new central coolant feed, better than having it run off the side like it does now. The taller deck of the new VQ35 should make stroking easier as I bet the VQ40 block is of the same height. Easy crank and rod swap then. I also like the CVTC solenoids on the front cover rather than on the cam cover. Can't wait to see what the power figure might be when this thing goes into the Z.
Will
Old Aug 30, 2006 | 08:13 AM
Eazzy's Avatar
Eazzy
I scanned and maybe missed it --What has been done with the bottom end as far as toughening things up ?
Old Aug 30, 2006 | 08:26 AM
  #38
fahrenheit350's Avatar
fahrenheit350
Now there's a reason to do dual varis air ducts.
Old Aug 30, 2006 | 08:34 AM
  #39
o snap its eric
ya more oem parts to put on our motor to make it faster, starting to sound like a honda fan
Old Aug 30, 2006 | 08:43 AM
  #40
doskiez's Avatar
doskiez
i bet that thing would scream with 2 popcharger type intakes OoOoOoOo
