Just received my UR crank pulley..
Old Sep 1, 2006 | 01:51 PM
dingobiatch's Avatar
dingobiatch
Default Just received my UR crank pulley..
Just got my UR crank pulley today (won it in a raffle, so it was free hehe). But I'm unsure if I should actually get it installed. I'm so worried, I keep seeing threads about how they wobble and screw things up and when you try to remove em, they break things. Doesn't sound promising. I'm tempted to sell it and get something else instead, but I want people's opinions. Is there really much of a difference when it is installed?
(In case I do sell it, how much would it go for new, unopened?)
Old Sep 1, 2006 | 02:32 PM
JhayRCruz's Avatar
JhayRCruz
ive had my UR crank pulley for 8 months i think and i have no probs. U'll feel a diff when u install it. From my experience, my rpm seemed to rise faster through redline. You might be able to sell this from $150-$200.
Old Sep 1, 2006 | 03:34 PM
___DJK___'s Avatar
___DJK___
I installed mine recently and I blew my engine.
j/k. Do a search, this topic has been beaten to death. Bottom line is no one has been able to prove these pulleys do any damage to this engine.
Old Sep 1, 2006 | 07:01 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
2 years 10 months with mine on.....never a problem
if you search, you'll see not a single person has ever documented a problem as far as I can recall. Alot of "my friends uncle's car" sorta stories
Old Sep 1, 2006 | 08:38 PM
350Zteve's Avatar
350Zteve
My engine actually exploded as the pulley was dropped off by UPS
Old Sep 2, 2006 | 09:49 AM
bofa's Avatar
bofa
I'll buy it!!! PM me if you decide to sell it.
Old Sep 2, 2006 | 11:26 AM
Nano's Avatar
Nano
yeah... lol, the strongest supporters of the "all your engine are belong to us" are the people who never had one, or know someone who knows someone who's cousin had the engine imploded.
Had mine on for around 2 years 20 miles, no issues.
-engine doesn't burn oil
-oil analysis at every 6000 miles flawless
Old Sep 2, 2006 | 02:32 PM
dingobiatch
Okay, well maybe I will install it :-P
So if I do, I will need a belt for it (didn't come with one).
I read that I should just 'go to the local auto place and pick one up', but I have absolutely no idea what kind of belt im looking for..
Old Sep 2, 2006 | 07:25 PM
___DJK___'s Avatar
___DJK___
Im using gates belts
http://mynismo.com/products/?ID=4325
Old Sep 8, 2006 | 08:49 PM
dingobiatch
...there are two belts? If I only am supposed to use one, which one do I use (I just ordered those gates belts)
Old Sep 10, 2006 | 01:59 PM
Ztalker's Avatar
Ztalker
DIY...one of the better mods for the buck. (you'll need a breaker bar to loosen the bolt and don't forget to use a torque wrench)
Old Sep 10, 2006 | 04:17 PM
dingobiatch
Not doing it myself, not worth the possible mistakes. I couldn't figure out how to do my own MREV2 or 5/16 spacer, I'm not going to try installing the UR pulley (with the horror stories that I've heard.. though I know I shouldnt worry about that..)
Old Sep 10, 2006 | 07:48 PM
jtgli's Avatar
jtgli
dingobiatch, not to hyjack ur thread or anythin but a quick ? for ya. I have an 06 tournin and just wanted to kno how you like the mrev+ and the 5/16 spacer? Did you notice a good increase in power and would you recommend this to another revup motor?
Old Sep 10, 2006 | 09:29 PM
Armitage's Avatar
Armitage
If you decide not to install the pulley, I'll take it off your hands.
Old Sep 11, 2006 | 10:37 AM
Ztalker's Avatar
Ztalker
just follow the instruction that comes with the pulley, everything will be fine. There is enough room for the breaker bar to get to the pulley bolt w/o removing the radiator. The stock pulley can be pulled out by hand after removing the bolt. i've had mine installed for two years and not a single issue except that the new belts had to be re-tightened after two weeks....good luck. There's nothing more satisfying than knowing a job is done right and you did the job yourself.
Old Sep 11, 2006 | 12:31 PM
Brian@Performance's Avatar
Brian@Performance
Performance Nissan
Originally Posted by ___DJK___
Thank you.
Old Sep 11, 2006 | 12:54 PM
dingobiatch
Originally Posted by Brian@Performance
Thank you.
Haha you got my business.
And to the poster a little back, the MREV2 and 5/16 spacer were the best mods I've done. My friend with a Legacy GT B-Spec I couldn't beat even after my HKS, popcharger, and high-flows. But the second I got the plenum mods, I could get a car or so on him. Soo...
Old Sep 11, 2006 | 07:28 PM
jtgli's Avatar
jtgli
So ill say that its worth it then on the revup haha. Oh yea, with the spacer, the stock stut bar is retained right, you just have to use spacers?
Old Sep 12, 2006 | 07:06 AM
Brian@Performance
Performance Nissan
Nice! Thanks!
Yep! You should be able to retain your strut bar with the 5/16" spacer.
Old Sep 12, 2006 | 07:28 AM
drap660's Avatar
drap660
Quick ?... For an 06 revup which mrev is better... mrev,mrev+ or mrev 2?
