What to do after cracking a head?!
Old Sep 12, 2006 | 07:59 AM
Silkk's Avatar
Silkk
Default What to do after cracking a head?!
EDIT: See post #4 below.
Thanks for any advice.
Old Sep 12, 2006 | 08:56 AM
EM-EFER's Avatar
EM-EFER
Buy some used heads and have head games work them over. Also do cams while it is apart. It will still be reliable.
Old Sep 12, 2006 | 09:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I have used Z heads for sale-PM me if interested.
Old Sep 12, 2006 | 10:15 AM
Silkk's Avatar
Silkk
Well, just got a call from the dealer. It's not even a cracked head. Or coolant leaking out the exhaust. It's actual 93 octane fuel...
Apparently injectors #1 and 3 weren't firing correctly?! They suggested I replace all 6 injectors for a total cost of $1400...
What does everyone think of this?!
Old Sep 12, 2006 | 10:26 AM
Q45tech's Avatar
Q45tech
Ah the benefits of ethanolized gasoline...........with it's wonderful addition of residual water in station tanks. Hearing many stories from NEast and Texas where the conversion from MTBE was bad news.
Old Sep 12, 2006 | 10:29 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Id buy injectors off the boards and swap them in less than 1 hour, WAY cheaper than $1400. BTW why would the new gas cause this? How much water in these tanks?
Old Sep 12, 2006 | 10:31 AM
Silkk's Avatar
Silkk
How hard is it to swap the injectors Alberto?
You said less than 1 hour? Where does the $1400 come in?
Old Sep 12, 2006 | 10:35 AM
Philthy's Avatar
Philthy
Boost Junkie
I'm sure you can find a set of stock injectors for sale from all of the people that went FI - I still have mine laying around collecting dust...
Old Sep 12, 2006 | 10:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Taking my time, in the garage about 1 hour to pull the upper/lower plenums off and swap injectors.
Old Sep 12, 2006 | 10:46 AM
Silkk's Avatar
Silkk
Alberto,
Interested in doing the job for me if I can find some stock injectors?
I'll pay you well...
Old Sep 12, 2006 | 02:17 PM
dTor's Avatar
dTor
Because the injectors, from the dealer, are about $150 each.
Old Sep 12, 2006 | 03:17 PM
JETPILOT's Avatar
JETPILOT
Injectors here on the classified board sell for about $100 per set of 6.
JET
Old Sep 12, 2006 | 09:15 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Alberto,
LOL, $1,400. I would definitely either find a local shop or get the shop manual and do it yourself after purchasing some used injectors from the FS section. It really isn't difficult at all. If you need a shop manual, let me know.
Old Sep 13, 2006 | 04:33 AM
Julian@MRC's Avatar
Julian@MRC
$1400!!!LOL, we charge 1-2 hours labor to swap injectors..F'n dealers man....
Old Sep 13, 2006 | 09:40 AM
Silkk's Avatar
Silkk
Well, I got some injectors off the board for a buck 25 and went to ask Nissan about labor only. They still wanted 550-600.
I believe I'm having the car towed home and I'm going to either do it myself or get a local mechanic to do it... I believe I could easily do it myself with that shop manual someone mentioned?
I just don't know the torque specs etc. to retorque the plenums and other pieces...
Old Sep 13, 2006 | 12:14 PM
Silkk's Avatar
Silkk
Found the service manual. I should be good to go now... Ordered the lower plenum gasket from nissan also.
Anyone have any thoughts on the kinetix plenum with pre-adhered gasket? Can I safely remove and reinstall this with the same gasket? Or will it need sent back to Kinetix?! If thats the case, I plan on just buying the motordyne or something...
Old Sep 13, 2006 | 12:45 PM
ACEMAN's Avatar
ACEMAN
Master
Your gasket should be fine, just take your time with removing it. I know i had mine off and on atleast 6 times.
Glad it wasnt your heads
Later
Aceman
Old Sep 13, 2006 | 01:05 PM
Silkk's Avatar
Silkk
Later
Aceman
Yeah me too!
Old Sep 13, 2006 | 01:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hint: INCH-LBS not ft-lbs.
Old Sep 13, 2006 | 02:04 PM
Silkk's Avatar
Silkk
The torque specs are on the service manual, so I think I'm good to go. Most of them are inch/lb. however Some of them are foot lb. although not much (I think 11-13 ft. lb. is the max i saw).
